Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Refrigerator is not cold but freezer is still operating.
My refrigerator is no longer getting cold although it sounds like the compressor is running. This has been the case for about 2 days now. The freezer (bottom mount) is still working fine. Any ideas? This refrigerator was purchased in April of 2005, so is less than 2 years old.
  • 2 more comments
  • Brad Potter Jan 10, 2007
    Thanks for the reply. I checked the fan (took off the bottom panel in the back) and it was definitely working. There was no ice forming on the coils.
    While I was back there, I did notice that the coils at the bottom of the fridge (accessed via the faceplate at the bottom front of the fridge) were covered in dust. I used a vacuum to clean these off. I also turned the Energy Saver switch off (not sure if that's related).....
    But, after plugging the fridge back in (following the cleaning of the coils) - everything now works. I also turned the energy saver switch back on and it still works (after 2 days).
    So, maybe I shouldn't care, but it would be really nice to now what fixed it, since if I don't it's sure to happen again.
    Any ideas what might have cured the problem (can dusty coils really prevent a fridge from cooling?) Thanks.
  • Anonymous Mar 02, 2008
    frig not working freezer is-purchased in april 2005-interesting that others have had same problem in same amount of time-help
  • katt442 Jun 15, 2008
    new kenmore refrigerator 253 7 months old. The freezer is perfect but the refrigerator is not getting cold?
  • Anonymous Mar 20, 2014
    This refrigerator has developed a very loud vibrating noise when the compressor runs. What's causing this?
  • 237 Answers
Couple things, both doing with air flow. If the fan in the lower freezer isn't working there will be no cold air moved into the upper fridge. If the defrost cycle happens to be dead then the coils down there will freeze solid and there can be no air flow over them to cool the upper area. You'll have to pull the lower drawer out and take off the interior rear panel to check these things. Hopefully it's just that the fan motor went out. It's real easy to change. Let me know what you find, if the coil is all iced up solid then there's more things you need to look into.
Posted on Jan 08, 2007
  • Marc Wilson
    Marc Wilson Jan 24, 2007
    If the refrigerant level is really low and the coils were REALLY dirty and not releasing heat I guess it "could" be possible. Cleaning will always improve how efficient it is but shouldn't really stop the cooling process like that. Oh, the energy saver switch is to allow electric heaters to keep the door seal areas warm so they don't get moisture forming water droplets on them. In dry areas, with low humidity OFF is OK, in the wetter areas of the country ON is preferred to keep the sweating down.
Refrigerator and freezer not cooling
Hi Kirk Huggins - Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the refrigerator could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor or evaporate fan. Contact a professional to accurately pinpoint any potentially more serious issues and to assist with the repairs.
Jan 27, 2013 | Frigidaire FRS26R4A Side by Side...
My refrigerator and freezer are no longer cold. It must have happened over night. It sounds like it is running but there is no cold air coming from the vents. Any suggestions?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Stopped cooling but the system appears to be running although we hear clicking sounds
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
Not cooling at all since the last three days .The freezer is not working either although the light comes on and the sound also can be heard.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and refrigerator are not working Awoke to defrosted food in freezer and food no longer cold in refriferator
replace the rtc contactor overload on the compressors side body,it supplies current to start and operate the compressor,if the relay on the overload goes bad the compressor will try to run on the start windings and overheat and will not operate to cool the unit properly even if it sounds like its running,it just unplugs from the compressor
Jan 31, 2010 | Refrigerators
Freezer willnot longer get cold only cool air
Do you hear the compressor humming? If the compressor does not run then your freezer will not get cold.
Aug 30, 2009 | Kenmore 54263 Stainless Steel Side by Side...
Freezer and fridge not cold
Sounds like you have a stuck compressor. The buzz is the compressor trying to run but cannot.
A refrigeration mechanic with an hermetic compressor tester can reverse operate the compressor to get it unstuck
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator not cooling very well, upper freezer appears tobe ok
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Kenmore Refrigerators
Amana refrigerator
Sounds like it has either a bad compressor relay or if the brand name of the compressor is Tecumseh, it will need to be retrofit to a more reliable longer lasting Embraco compressor.
Jan 10, 2008 | Amana ARB8057CSL Bottom Freezer...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
544 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
