Question about Canon PIXMA MP160 All-In-One InkJet Printer
Trouble with printer
Okay so im having more then 1 problem not only will my printer not print from my computer but when it does it has lines through it like something needs aligned. can you help?
  • 385 Answers
Just Replace the cartridges they are most likely clocked!
Posted on Nov 28, 2008
HP PSC 1210 stopped working on a Dell desktop running Vista
Uninstall the drivers again, restart the computer, turn off antivirus, install drivers again, plug cable to another usb port when prompt, if firewall shows pop up window always choose allow or yes. Also make sure that printer is not working "off line", go to control panel, printers and faxes, right click on the printer that you want to use, check if it says "use printer off line", if it does, click on it and it will change to on line.
Sep 01, 2009 | HP PSC 1210 All-In-One InkJet Printer
Color prints come out too light with lines
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Mar 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Computer can't find my printer
you may try to make sure:
1) PC detect your printer when you plug the USB cable in (PC has 2-4 USB interface) and power on the printer, then you can see the indication on the down right of windows bar( indicate find a new device if no driver installed) , it means your printer connection is normal. if windows can not detect your printer go next
2) check USB cable might be some where disconnection, or change another cable, check the the sockets (two side jacks needed), still trouble you may change another PC to test.
Feb 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Print Problem
free needed software for lexmark x75
Aug 03, 2008 | Lexmark X75 All-In-One InkJet Printer
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
