Question about Fujitsu S6120D PC Notebook
Fujitsu S6120 laptop power problem
My Fujitsu S6120 laptop, with the power-supply connected, keeps going into "standby" mode thinking there is no power. The power socket has a slight wiggle and I think is the source of this problem. Can some tell me how to get to the motherboard of my laptop? There are a bunch of screws on the bottom of my laptop and a couple of screws in rear of the latop. Do I need to remove all of these screws? Thanks.
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
I fixed my S6210 wen the poorly designed connector broke. Fujitsu wanted $ 250 to do the job. The part is only $ 5. I also bought a Cable Retention Device to keep from jerking on the cable.
Here's a video that talks about the problem and the cure.. . .
Posted on Mar 04, 2008
  • 624 Answers
Hi Altos, I found lots of people suffering from the same problem, the DC connector is only held in place by the contacts soldered on a small circuit board. It?s a poor design and apparently Fujitsu will do free repairs as long as it?s still within its warranty period otherwise you have to pay. Another option is to pay to have someone else do the job for you. I found one shop one Ebay of all places. Here is the link: http://cgi.ebay.com/FUJITSU-LAPTOP-MOTHERBOARD-AC-DC-POWER-JACK-REPAIR_W0QQitemZ320067658030QQihZ011QQcategoryZ51162QQssPageNameZWDVWQQrdZ1QQcmdZViewItem If you have fairly good mechanical skills and are not afraid of ruining your laptop further you have another option, disassemble the laptop and repair it yourself. This is generally not an easy task for the typical user and I need to reinforce that you need to be fairly comfortable using tools, doing low wattage soldering on circuit boards and working on small, fragile plastic parts. Unfortunitly I have never worked on a Fugitsu laptop nor was I able to find any instructions on anything other than a S2000 series. Again from what I have read disassemble is *similar*, here is that link: http://www.leog.net/fujp_forum/topic.asp?TOPIC_ID=8382 This site should have your replacement DC jack. http://www.laptopjacks.com/index.php?brand=10 I also poked around Ebay and guess what, they sell the same part: http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R10&satitle=fujitsu%20jack&sacat=-1%26catref%3DC6&bs=Search&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp=&sargn=-1%26saslc%3D2&sadis=200&fpos=95035&ftrt=1&ftrv=1&saprclo=&saprchi= Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 09, 2007
How can i find the mac address of s6120
1. Click the Start Menu
2. Click on "Run"and type in cmd
3. Type in ipconfig /all
4. If you find your connection, it should say Physical Address!
-JH
Sep 01, 2013 | Fujitsu Siemens LifeBook S6120 Notebook
Lifebook s6120 does not start - dead i can't turn it on do i have to clean the motherboard or something else plese help!!!
unplug from the power and also take out the battery.
now hold the power button down for 30 seconds.
put the battery back in and hook up the power and try to power it on again.
Mar 24, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
Will not load anything it says error loading operating system
Have you tried booitng into safe mode? hold F8 down after laptop finishes post test. this will then go to a black and white screen and you need to select "safe mode". also are there any cd in the dvd drive? and the hard drive is set to boot first in bios.
Jan 18, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
When i want to install windows it doesnt show mine hard drive. i lookd in bios but it says none,i tryd to replace the hard drive but still nothing. mine laptop is an fujitsu siemens s6120. hope u have...
Make sure that the HDD connector are connected properly.
The power connection are OK? Set the BIOS as default and check.
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 23, 2010 | Fujitsu Siemens LifeBook S6120 Notebook
My wifi wont work. I dont have the driver. the ones i downloaded wont drive it. pls give me a hint on what to do? I use lifebook s6120 fijisu siemense
There are some wireless drivers at the bottom of http://www.drivershq.com/Drivers/Fujitsu-Siemens/Lifebook/S6120/24971/45495/48955/Drivers.aspx
Oct 12, 2009 | Fujitsu LifeBookS6120 Notebook
S6120 didn't take 250GB memory
hi Barch
every processor has three types of buses.
  1. address bus
  2. data bus
  3. control bus
The size of address bus is responsible for the number of memory locations a processor can access.
The size of address bus is fixed for each processor.
Your processor can address that many memory locations only through its address bus.
That is why anything more than the limit of memory location is waste.
Thank You
Jul 15, 2009 | Fujitsu LifeBookS6120 Notebook
Fujitsu power supply shutdown goes to standby mode. no picture. If I turn it off for a while I get great picture and after a while it shuts down and goes into standby mode. Is this a power supply that is...
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in the P42HHA10 model. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A similar Service Bulletin is probably available to suit your model. A competent service technician should be able to implement the service bulletin.
Jun 02, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
Power on my Fujitsu Seimans Lifebook B-2154
Does the laptop get very warm? It may be overheating.
May 06, 2008 | Fujitsu LifeBook B2154 Notebook
Fujitsu-Siemens - Batteries won't charge
Whats the spec of your power supply (approx 19v dc @ 3 - 4 Amps...)
Voltage 'OFF LOAD' is irrelevant - its the power consumption (A) that you need to validate (Do not measure directly)
Does the Laptop power up under mains feed ?
Is your concern mainly the fact that the battery(s) are not charging ?
Mar 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu S6120D PC Notebook Logo
655 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
