Question about Sharp Microwave Ovens
Sharp R-402 JWF halfway through cooking, quit cooking but time kept on counting down.
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views at the Sears parts site.
Once you have the part number from the Sears site, you can often get the parts cheaper here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Nov 27, 2008
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Sharp R-520 JKF
No! The problem is one or two bad door switches, or possibily the keypad control board.
Apr 11, 2012 | Sharp Microwave Ovens
Sharp Microwave stopped working. lights up, counts down. Fine'
High voltage power supply for the magnetron is likely problem. Multi-thousand-volt section--be careful.
Jul 11, 2009 | Microwave Ovens
Timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 24, 2007 | Frigidaire FMV156EM Microwave Oven
No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Apr 26, 2007 | Sharp R-1492 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
