Question about Microsoft Xbox 360 Console
No sound and purple lines running down the screen
The system turns on fine but there is no sound and these purples lines just run down the screen
  • 2 more comments
  • Anonymous Dec 10, 2008
    i have the purple lines running down the screen problem but i do have sound.
  • Anonymous Jan 04, 2009
    same problem
  • Anonymous Jan 18, 2009
    when we turned on the x-box 360 all we heard was the sound of the menu come on,but nothing eles, and there are purple ish pink horizontal lines running across my tv screen.
    does anyone know why???
  • mdhatter Jan 21, 2009
    Our XBox 360 has been working great with not problems. Played Madden and turned the HDTV off and the XBox off. Turned they back on later, and I get the purple-pink waving lines running horizontally, but I get sound. I've unplugged all of the video cables and plugged them back in, but I still get the same thing.
    Any thoughts?
    Novelist:
  • 174 Answers
Hi, this is caused by overheating on the memory chips. The xbox 360 gets so hot that the mainboard warps and in turn cracks the soldering which gives you this type of problem.
we offer a full repair of this type of problem which includes an x-clamp replacement, re pasting of the chips and also an addition of a team xecuter repair kit. we also go over the mainboard re-soldering any joints we can to eliminate this type of error in the future. www.fixmyconsole.co.uk
Posted on Jan 18, 2009
Grundig lcd tv has vertical purple lines that fade after a few minutes
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Grundig Televison & Video
Purple screen
Sustain board fault. Contact any service technician. It is a skilled work to locate the exact faulty sustain board. Gopakumar Gopalan Google
Mar 09, 2014 | Fujitsu P55XTA51US 55 in. HDTV Plasma...
Code purple when turning on computer
Code Purple is a problem exclusive to HP's, the easiest solution is to avoid them. However, it's already too late for you as it was for me. Basically it's an attempt to force you to pay them to service or upgrade your PC, or if you didn't learn the first time, buy another. Here is the most concise answer I found, tried to translate into plain english.
***PLAIN ENGLISH QUICK AND EASY FIX FOR ALL SYSTEMS****
***Windows 7 code purple or Windows Vista code purple***
With the code purple error on the screen, press shift+f10 (the shift key and the F10 key (at the top of the keyboard) at the same time) to open a little screen called a command prompt. (So, you get a little black screen with white text that says something about your Windows verison first and a little ways down you'll see "C:\>". It's all ready for you to start typing.)
Type the following line, just as you see it here...
notepad C:\hp\bin\checkdmi\checkdmi.cmd
so it will look like this C:\>notepad C:\hp\bin\checkdmi\checkdmi.cmd - Note the space between notepad and C:\
Press Enter.
You will see the text for the file listed in a window using a simple text editor.
Go to the beginning of the text. Press enter to make a space. Type this...
goto cleanup
So, whatever comes after, the first line looks like this...
goto cleanup
Save the file and exit notepad and restart your PC. You are good to go
NOTE: From my experience. If you received the Code Purple error during the restore process; after saving and exiting notepad, press and hold the power button until the PC shuts down, wait 15 seconds then restart. If you get a message during start up select "start windows normally". If you don't shut down using the power button and wait for the "windows was unable to finish........", you will likely get the same error again when the system boots. I don't know how to get back to the Code Purple error without doing the restore process again.
Feb 10, 2013 | HP Computers & Internet
I have a purple line running up and down my 42" sanyo?
Hello; If this purple line goes fully from top to bottom, You have a bad LCD panel. If the line goes only part way down or up the screen, You likely have a cracked LCD panel ( never covered by warranty ) The LCD panel will cost more than the set sold for ! John
Jan 22, 2011 | Televison & Video
Purple line running down screen
Hi! Try to uninstall and reinstall video driver in dev manager.If it doesnt work then check if it happens in bios if yes then it might be the video card that you need to replace, if video card is built in then you need to replace the motherboard.Try to use a external monitor and check if your seeing the same thing on the ext monitor if yes then its the monitor, if its under warranty your manufacturer will replace it for you.Hope this helps...
May 25, 2010 | Computers & Internet
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Projector Colour Problem
Could be a few things....first you need to isolate a signal source issue or a faulty LED lamp. Simply unplug your signal source and run the menus on the projector. Purple Gone with source unplugged = faulty source our signal Purple still there = faulty device Sounds crazy but make sure you have no interference devices running real close within say 2 feet. cell phone, microwave, magnets, high voltage eletricity...etc
Jun 06, 2007 | Offspring Technologies C5YP-BIN-25 25...
Microsoft Xbox 360 Console Logo
716 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
