Question about Brother HL-2040 Laser Printer
Brother HL 2040 - Notecard sized paper jam (you responded)
Hi - I posted the question about the notecard sized paper jam. I was wondering where the access cover is located (as you can probably tell, I do not know much about printers). Is this the access cover located on the underside of the printer, once you remove the paper tray; or is it the top portion of the machine? Sorry to bother you, but I do appreciate your help!! Thanks!
    Genius:
  • 2,035 Answers
Access cover is the cover where open to replace the cartridges , once you open that check for any paper stuck ....if still cant find carry with envelope procedure in the troubleshooting steps given earlier , Its place were we are ready to help people ......
Good luck....
Posted on Nov 27, 2008
My Brothers Printer has a paper jam. How do I free it?
Hi bfoote44,
Kindly click on this link for the complete step by step procedure on how to troubleshoot paper jam on your Brother HL-2040. It's easy to follow since illustrations are also provided.
Hope it helps.
Thank you for using Fixya.
Jul 01, 2010 | Brother HL-2040 Laser Printer
I have a paper jam in my printer. The paper is
You will have to open the Printer door and pull the paper out if you are lucky it will pull out in one piece if not you will have to get all the pieces out before it will operate again. When pulling out go very easy with it and move your fingers down with the paper to apply force at the closest point to where the paper pulls into printer.
May 13, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
I'm trying to print some photos on 4 x 6 paper. i selected notecard paper size, but the printer keeps printing the 4 x 6 photo on 8 1/2 x 11 paper.
Are you telling the printer to use the smaller paper?
If it has 2 sizes it will keep using the last size used unless you tell it to change.
Sep 27, 2009 | HP Photosmart 3210 Printer
Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
May 27, 2009 | Brother HL-2040 Laser Printer
Notecard sized paper jam - can not find in usual spots
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Printing mailing list
Sounds to me like the word doc's page size is not set to the same as your printers tray.
In word, file , page set up. page size/paper size is set to "letter" in US I think is standard, it's A4 in Oz
On printer driver check page size setting too
Contral panel, printers and faxs, RIgHT click on brother printer icon, properties, printing preferences, page size
post back
Nov 17, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
