Question about Panasonic KX-FL511 Plain Paper Laser Fax
Fax document jam
I have a Panasonic KX-FL511 laser fax. It draws the paper to be copied into the machine and then copies perfectly. When I try to send a fax, it draws the paper to be faxed in about 1 inch,stops and proceeds to tell me there is a document jam. Why am I only having this problem while trying to fax a document? Help Please!!!!! I tried just now and I dialed 3 times to fax. Each time it took in the paper a little farther and when the third try dialed up it took in the sending document and faxed completed to destination. Why????????
  • StanD Nov 22, 2007
    I have a similar problem. My work around is to feed one sheet at a time but this is really a pain.
    I hope someone knows the solution!!
  • Anonymous Nov 30, 2007
    I have a Panasonic KX-FL502 laser fax. It draws the paper to be copied into the machine and then copies perfectly. When I try to reseved a fax, it draws the paper to be faxed in about 1 inch,stops and proceeds to tell me there is a document jam. Why am I only having this problem while trying to fax a document? Help Please!!!!!
I poured vodka onto the paper and feed it in and it worked! (Earlier, Tried cleaning it but it didn't work)
Posted on Sep 09, 2010
Also have the same problem today, called the "help" line 800 435 7329,
her command of the english language and her tech support just added to the problem. She first suggested that I clean the rollers with alcohol, she asked it as if I had a bottle of achohol just sitting @ my desk, so I cleaned them, (after finding a bottle) - cleaning didn't do anything - then she said to locate the "cork and white plastic piece under the tray, I couldn't find it, she really wasn't more help in locating this, so I said thanks and hung up. Later this morning I proceeded to examine the unit further I found it not under the tray but on top of the inner tray . I played with it somewhat pushing it up against the part it was attached to, that at least allowed me to send the fax I needed to send. I'll call them back and see what the next step was supposed to be, now that I know where the part is. So as you can see this cork/plastick part is the cause of the "document jam"
Posted on Sep 03, 2008
    Problem Solver:
  • 12 Answers
The document feeder rollers could be dirty. Try cleaning them with a lint-free cloth (not paper) and some alcohol. A commercial platen cleaner is best if you can buy some.
Posted on Jan 27, 2007
Document jammed
It sounds as through the paper jam sensor is either dusty so needs a clean, or the sensor has stopped working totally & needs replacing, if this item is still under warrentee I would call the company for the repair, if not a local computer repair company will be able to assist you further, most offer a free quotation service if you ask...
I do hope this helps resolve your problem, if you could reply & let me know the outcome, many thanks...
Feb 22, 2018 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
Jul 07, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Need owners manual for kx-fl511
go here for PDF copy of manual.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Jan 18, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
I have the Panasonic KX-FL511 and when we receive faxes we can not read down the center of the page. Does this need a new drum?
yes but try cleaning corona wire first, clean corona wires Gently with a #2 pencil eraser, then try making a copy again
Jul 09, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
Feb 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX_FL 520 Fax problem
THE DOCUMENT SENSOR OR THE DOCUMENT END SENSOR ARE EITHER BAD OR THE SENSOR LEVER IS STUCK OR BROKEN CHECK THESE AND YR PROBLEM WILL BE RESOLVED HAPPY FAXING OMNIPRESENT
Sep 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
302 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
