Question about Crane Thomas the Train Humidifier
Thomas the train -Broken part
I have a Thomas the Train humidifier and there is a little clear plastic round part with a seal that is attached under the top half of the humidifier where you put in the water. Without this part the water would not stay in. A certain amount of water does leak out - I think it's meant to be that way, but not all. The part broke off for some reason, and I was wondering if it is ok to reattach the part with plumbers putty myself, or if there is another solution.
3 Suggested Answers
  • 10 Answers
SOURCE: Is it ok to put a piece of plastic under the
Yes, as long as it doesn't interfere with air flow of the unit.
http://www.my-air-conditioner.com
Posted on Nov 08, 2009
  • 15 Answers
SOURCE: Very little water left/ fills up and leaks
**With the unit unplugged**
the float sensor is probably getting sticky with residue and buildup (lime, grime, etc). Try cleaning the little float and that area. It should move easily when clean.
Posted on Dec 22, 2009
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
Is a kaz water tank leak under warranty?
I doubt if there is any warranty on this now. It has been over three years ago.
May 18, 2017 | Honeywell Humidifiers
My ultasonic humidifier is not working
Make sure it is plugged into an outlet that works with a lamp or other device. If it does, try wiggling the cord to see if there might be a broken wire inside that you can get to activate (to diagnose as a broken wire in the cord). If that doesn't work, try wiggling the switch.
Also, make sure the tank is properly placed. - look for any little micro switch sensors that are pressed in when the tank is properly placed. Try pushing these in manually to get it to start (if there are any).
There red may also be a light sensor to see if the tank is clear enough before starting - prevents people from infecting themselves with moldy water. Cleaning tank with vinegar and then dish soap is a good idea.
A new switch or cord is a possible repair. Others are difficult.
If this does not get you up and running, any circuit board repairs will be more expensive than a new one. You will have to consider it unrepairable. Either return it to the store if still under warranty or send it to the dust bin (or recycling).
Mar 14, 2014 | Kenmore Cool-Mist Ultrasonic Humidifier...
Honeywell humidifier htt-145 leaking from bottom
If you can locate a crack in the clear plastic tank, there may be a chemical you can buy to "weld" the crack closed. If you aren't sure what plastic it is, you might try sealing the crack with bathroom caulk that is mold resistant. You must locate the source of the leak and patch that.
Mar 08, 2014 | Honeywell QuietCare HCM-630 Humidifier
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
What is the saddle valve?
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
May 07, 2010 | Aprilaire 550 Humidifier
Doesn't seem to turn on when I plug it in.
Feel the body of the train humidifier, I hope it's warm.
Otherwise,. it is not working. Unplug the unit, and check
the power terminal fuse, it could be busted. If it is okey,
then it is the heating element that needs to be replaced.
May this tip help you.
Jan 06, 2010 | Crane Thomas the Train Humidifier
No water flow in humidifier
clearly your water pump is broken. or you solonoid
Nov 11, 2009 | Aprilaire 600 Humidifier
Emerson furnace is not igniting
limit switch may be stuck open.open top door on furnace switch is round with little black hose on it. disconnect hose from furnace side and **** on it to see if it will close.reconnect hose and try furnace
Dec 05, 2008 | Honeywell Power Humidifier: Furnace...
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Crane Thomas the Train Humidifier Logo
147 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
