Always Paper Jam in Epson Stylus CX3500
I have Epson Stylus CX3500
When I print something
It always told me that it had a paper jam
but the paper didn't jam
how can I fix it?
(sorry for my bad english)
  • nut29951 Nov 26, 2008
    how to feed a #10 envelope through the left side of the manual feed?
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Nov 26, 2008
  • Anand Kumar
    Anand Kumar Nov 27, 2008
    Make sure that envelope in thick long strip so that it is long enough to make a loop that it cover paper feed to paper exit tray.. once you done follow the procedure....
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
THE EPSON STYLUS CX7800 KEEPS SAYING THERE IS A PAPER JAM, BUT IT'S NOT. IT TRIES TO PULL THE PAPER THROUGH, THEN STOPS. IT DOES NOT ENTER FAR ENOUGH TO EVEN BE JAMMED. IT APPEARS THAT IT IS TRYING TO PULL...
The sensor lever was stuck and still blocking the sensor and that is the reason why it always say paper jam.You have to dismantle your printer if you do,you can find and trace the sensor where the paper is being inserted,most probably it is near the pick up roller (it is the one that gets the paper).
Sep 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Epson dx7400 printer jam
Turn off the printer and then open the scanner unit. Cancel the print job.
fon3_38.gif See Canceling Printing h018013h.gif step_2.gif Remove all of the paper inside, including any torn pieces. h018014h.gif step_3.gif Close the scanner unit and then turn on the printer. h018015h.gif
Aug 27, 2009 | Epson Stylus C86 InkJet Printer
Paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Jun 14, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
E4 comes up on panel saying clear paper jam
With out knowing which stylus you have there error either refers to a paper jam or ink cartridge error. If it takes the beging of the paper but then stops it could be a matter of worn rollers that are not able to grip and move the whole page.
Nov 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Paper jam error
your software doesn't have problems... its your printer itself or the way you put on the paper that's why its always having error....
Feb 14, 2008 | Epson Stylus Photo R300 InkJet Printer
435 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
