Mi ipod nano has gone dead and does not respond to wat ever i do
SOURCE: iPod Nano Faceplate
hhhhgututgut8tiiui
Posted on Mar 06, 2008
  • 13433 Answers
SOURCE: 8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Posted on Mar 25, 2008
Try resetting into disk mode by holding down "MENU" and the centre round button for a couple of seconds at the same time, let it charge for a couple of minutes - important, eject it from your hard drive first, quit all applications that work with your iPod, then press the "MENU" and round button at the same time again press the play button - it should go to a grey screen with a apple on it - re-atach your iPod to the machine again - it should now look like its charging, and should launch iTunes again giving you full functionality to your iPod again - let it fully recharge before unplugging.
Posted on Sep 01, 2008
Dipu007
  • 2110 Answers
SOURCE: ipod nano is dead
leave it on until the battery runs down.turn off and plug in to charge,Allow it to fully recharge.Turn on and it should have reset itsself.
Posted on Feb 11, 2009
  • 3422 Answers
SOURCE: my ipod wont turn on
If your ipod won't turn on then try these.make sure you click on the blue links for more info.
Make sure the Hold switch is off
  1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
ts1383_2.jpg To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
  1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
  2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Posted on May 16, 2009
I plugged my ipod nano into the computer and put it on hold. i didnt eject it i just took it off the plug. not it is frozen . its very dark with a connected sighn on it and i even tried holding down the...
You have not ejected the hardware in technically correct way so the software of ipod is not responding. You need to wait time the time its battery is gone and the ipod will work normally once your ipod is switched on again. You will not be able to switch off your ipod in this situation so please wait till the time battery is not gone completely.
May 28, 2010 | Apple iPod nano
How to unlock ipod nano
restore it thru itunes
Apr 27, 2010 | Apple iPod nano
MI IPOD MOD A1199 4GB NO LO RECONOCE MI PC
I have the Ipod nano 8g and the screen lights up but but get no menu and can't play anything.. I just go this ipod.
Apr 08, 2010 | Apple iPod nano
Ipod nano worked, battery died, now won't work
just leave it charge for a day or so that should do the trick
Dec 20, 2009 | Apple iPod nano
My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Dec 15, 2009 | Apple iPod nano MP3 Player
Ipod 4g only respond when plugged into USB
Check your battery. I feel the battery has gone. Dead as a dodo, as the saying goes.
Aug 08, 2009 | Apple iPod nano
Ipod nano is dead
Feb 11, 2009 | Apple iPod nano
I pod nano
my 4gb ipod nano wont turn on with full battery
Aug 22, 2008 | Apple iPod nano 3rd Generation
Ipod nano 4G
Reset iPod nano
(if your iPod nano isn’t
responding)
Set the Hold switch to Hold and turn it off again. Press the Menu
and Center buttons at the same time for about 6 seconds, until the
Apple logo appears.
May 22, 2008 | Apple iPod nano
Ipod Nano White 2Gb
The click whell might be bad or other components failing..
Heres my page on ipod problems
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
on the bottom you can find the service assistant to get it repaired by apple.
If apple costs too much you can try
http://store.ifixipodsfast.com/
May 16, 2008 | Apple iPod nano
121 people viewed this question
 Grubhead
Grubhead
