Question about Whirlpool EL02CCXP 19" Cold Pals Compact Refrigerator w/ 1.8 Cu. Ft. Capacity, Manual Defrost & Reve...
  • 112 Answers
SOURCE: Ge fridge 19 cubic foot
Ice is forming on your evaporator. Replace the defrost timer.
Posted on Nov 08, 2008
  • 9 Answers
SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Posted on Dec 08, 2008
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
Posted on May 29, 2009
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
  • 291 Answers
SOURCE: Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Posted on Jan 17, 2010
Testimonial: "Great info, easy to understand... hopefully the fix is as easy as the explanation!"
Model# FRT17B3JW6. need to know cubic ft. for selling
Normally the first two numbers in the model number are the cubic feet. You have posted 2 model numbers, on appears to be 21 cubic feet and the other is 17 cubic feet.
Jan 21, 2013 | Magic Chef CTF2125 Top Freezer...
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Sep 08, 2011 | Kenmore Refrigerators
I need to know the cubic ft of my old Whirlpool fridge. The model# ET18JKXDW01. Serial# 18TFA95. Thank you.
The first two numbers in the model number says what the cubic feet is, its 18 cubic feet
Aug 10, 2011 | Magic Chef CTF2125 Top Freezer...
The model of my whirlpool fridge is et1mtkxkq00. What is the cubic feet?
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Oct 24, 2010 | Refrigerators
I have a Kenmore model 795.7731 fridge and need the cubic feet of the model. Thank you.
Sep 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
Hello, RE a 1980 Kenmore 20821 Large capacity washer 1) the machine does not extract fully. I have tightened the belt which was loose but that has not corrected the problems. Also, I would like to know...
I would you recommend you make a burial date for that machine. The best ones out right now are whirlpool, or one of their models like roper etc... just get the standard models. I do not recommend front load models. This goes the same for the Fridge. The better one out is whirlpool, maytag and the other models are having a bad compressor issues... let me know if i can be more assist to you.
Apr 26, 2009 | Kenmore Washing Machines
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
Refrigerators Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
