Question about Kenmore 64892 Electric Dryer
Replacing a defective Terminal Block - Kenmore Dryer
Our Kenmore dryer (approx 6 yrs old) would continually shut off mid-cycle. After cleaning dismantling the motor compartment to vacume out all the lint I ran a load to test it. Everything was working great until I bumped the dryer. It shut off and wouldn't restart. I dismantled the wiring housing where the three prong is attached. It appears that the wiring wasn't tightened down to the "Terminal Block". I can only tighten the bolts to a certain point. There is alot of play underneath especially on right wire (which incidentally is stripped). 1) Is this an electrical hazard for my family? If it's connected and randomly loses power. 2) Is there a terminal block that would allow me to more securely tighten the wiring harness? Where can I order one of these? Thanks! Kenmore Dryer Model #60902990
  • 67 Answers
If there are any lose wires connected to the dryer terminal block and there is any sign of current draw like black around it or if it just looks bad in general then yes it does pose a threat of a fire hazard or electrical hazard like shocking you when u touch the frame. There is a terminal block you can buy for it visit any part place with the model number and they can help you out hope this helps
Posted on Mar 21, 2007
I have a kenmore elite dryer that is only 4 yrs old. It stops about 5 minutes into the cycle and puts up 2 codes. CLL and Sru what do these codes mean and can I continue using the dryer ?
Clean the entire exhaust duct from the back of the machine all the way out of the house, if the codes don't change. Call a service tech... CLL SRV = call for service
Apr 26, 2016 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
My kenmore dryer model#110.61202013 wont heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating
Feb 22, 2015 | Kenmore Dryers
Kenmore dryer not heating up
Feb 10, 2015 | Kenmore Dryers
My kennmore dryer model # 11062912100 won't heat up what is the possible cause?
May 05, 2014 | Kenmore 62602 Electric Dryer
My kenmore dyer about 16 yrs old died on me in mid dry. It will not start now. I checked circut breaker in home was fine. I checked continuity in push to start switch,Hi limit thermostat, 250 degree therm,...
Hello there and thank you for choosing fixya
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block that it is attached too
Jul 31, 2011 | Roper REX4634KQ Electric Dryer
Dryer shut off mid cycle and will not restart
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Dec 31, 2009 | Kenmore Dryers
Kenmore Dryer won't heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 09, 2009 | Kenmore 64902 Electric Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
Kenmore 64892 Electric Dryer Logo
1,015 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
