Home | Acer | Aspire 1642WLMi (LXA8605470) PC Notebook | Acer 1641 laptop key...
Acer Aspire 1642WLMi  PC Notebook
Problem for Acer Aspire 1642WLMi (LXA8605470) PC Notebook
Acer 1641 laptop keyboard doesnt work
By pgeorgi on Nov 26, 2008
we can plug ina USB keyborad which does work. also the touchpad is non functional but a plugin mouse will work
Solution #1
posted on Nov 03, 2009
Not Rated)
shahidr100
Rank: Wiz
Rating: 83%, 18 votes
Hi Kumar754
Thanks for the solution. I have an Acer 1642WLMI. My keyboard was not working. The system use to hang when i use to restart with battery on and the wirlesss also stopped working. I removed the battery and booted. All works fine. I have not inserted the battery back. BUT what if I really need a battery, because power will not be available on the move all the time. If I buy a new battery, can I boot it with battery inserted ?
shahidr100@gmail.com
Was this helpful?
Yes
No
Solution #2
posted on Jan 14, 2009
Not Rated)
kumar754
Rank: Master
Rating: 71%, 8 votes
  • shutdown and power off your acer laptop
  • then remove the battery out of laptop
  • connect the power and switch on ur laptop
  • let it boot to operating system
  • check if its working now? ur keyboard and mouse should be working now
  • you can now connect the battery and keep working.
  • if u want to power off, put ur laptop in hibernate more, rather than shut-down. so u dont have to reboot next time without battery.
  • if u restart or start ur laptop after a shutdown, make sure to remove the battery first
    i hope this will help.
more details can be found on the cnet forum @ http://forums.cnet.com/5208-6620_102-0.html?forumID=44&threadID=294657
Was this helpful?
Yes
No
Solution #3
posted on Nov 27, 2008
Not Rated)
pgeorgi
Rank: Apprentice
Rating: 0%, 0 votes
we removed the battery and used only the AC. all works fine.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 1642WLMi PC
Questions and Unsolved Problems for Acer Aspire 1642WLMi PC
Do you recommend Acer Aspire 1642WLMi (LXA8605470) PC Notebook?
Answer
Answer
I have a Toshiba Tecra M2 and I can not seem to find the audio controller or sound driver for the... (More)
Answer
I have a OKI ML391 turbo printer that i just purchased I need a user manual, the drivers for it and... (More)
Answer
My Hp mini is not turning on. The light next to the on switch is on but nothing happens on the... (More)
Answer
Hi! just bught a used IBM thinkpad 2626. how do i turn the damn thng on raymond d
Answer
how do i enable dell webcam 1521 built in. It works with yahoo messenger fine. But I use to be able... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 1642WLMi PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
