Question about Radio Shack Cinego D-1000 Multimedia Projector
I have problem wiht Cinego D-1000
The problem with my Cinego D-1000, is searching....... is not past that screen how can a reset.or is other problem somebody can help me thanks..
While it is frozen on that "Searching" screen, hold the SRC button down on the actual projector for an extended time. Then after letting it up, hit it briefly one or two times until it finds a source. Make sure that under Projector Setup/Management/ "Auto Source Select" is checked. This brought my Cinego back from the dead.
Posted on May 27, 2007
SOURCE:
Replaced bulb but unit goes through cool down then shutts off
You can't, since the unit doesn't have the ability to do what the remote can do. However, the remotes are inexpensive and easy to obtain. Simply type in "Cinego Remote" as a search expression on your search engine, and several places will pop up. Alternatively, contact your local Radio Shack store.
Jun 26, 2009 | Radio Shack Cinego D-1000 Multimedia...
My cinego d1000 overheats 5 minutes after i turn it on
Replace the heatsink and fan with a better one and make sure the proper amount of thermal paste is used (about 1 decent drop)
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Experienced techs waiting to help you with your needs.
Jun 24, 2009 | Radio Shack Cinego D-1000 Multimedia...
Rotation of screen
The Cinego only reverses the picture, so that it can be reflected from a mirror. It won't rotate the picture.
Jan 07, 2009 | Radio Shack Cinego D-1000 Multimedia...
SRC button on cinego projector will not read source
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego D-1000
I have the same problem with my cinego.
Maybe we should all sue Radio Shack to take these machine back
This problem is wide enough to issue a recall.
Dec 24, 2007 | Radio Shack Cinego D-1000 Multimedia...
317 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Pie-man
Pie-man
Colin Stickland
Colin Stickland
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
