Home | Acer | AcerScan 610P Flatbed Scanner | Driver for Acer Vue...
Acer AcerScan 610P Flatbed Scanner
Problem for Acer AcerScan 610P Flatbed Scanner
Driver for Acer Vuego 610P
By mikhly_solom on Nov 26, 2008
I'm using Win XP SP-2 and it can't see my Scanner I need the driver for my scanner. Can you send me the exact link to download it
Solution #1
posted on Nov 26, 2008
Not Rated)
ginko
Rank: Guru  Acer Computer Hardware  Expert
Rating: 89%, 5024 votes
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional of this procedure and installation procedures, please read the pdf file posted here:
scpinwxp-eng.pdf
from Vuego Scan
Was this helpful?
Yes
No
Popular Solutions for Acer AcerScan 610P Flatbed
Questions and Unsolved Problems for Acer AcerScan 610P Flatbed
Do you recommend Acer AcerScan 610P Flatbed Scanner?
Answer
Answer
i cant get the hp 2180 scanner to work when i press scan the on/off light just flashes and it brings... (More)
Answer
Scanner doesn't initiate
Answer
changing ink cartridges epson dx 7300
Answer
Please send me the drivers to use the scaner with windows Vista OS ?
Answer
I have a mercuty flatbed scanner 620P. But I have no software for the hardware. Previously I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer AcerScan 610P Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
