Question about Microwave Ovens
Ge spacemaker microwave has no power how do i change the fuse?
We don't know where the fuse is located to get at it it's a spacemaker xlJVM1851BF
GE Spacemaker® XL1800 Microwave Oven with Recirculating Venting
  • angels101776 Nov 26, 2008
    thank you for taking time to help me but we still can't find a fuse...
  • Anonymous Mar 23, 2014
    Where is the microwaves fuse located
  • 333 Answers
First you have to unplug your device. Next you must remove the cover from the micowave. Follow the powe cord to the unit the fuse should be right at the beginning of the powe cord. I hope yhis will help you.
Posted on Nov 26, 2008
My GE Spacemaker 2.0 over the counter microwave just died. No lights or anything.
Hi, It sounds like the internal fuse blew. To get to it, the case has to come off the unit and its located close to where the power cord ties in. With any and all microwaves, It is a good idea to put a surge protector on the plug to plug microwave into. Hope this helps.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker oven has stopped working. I need to know where the fuse is located
Buy a different brand...I have now 2 of these that don't work and the answer is always, pay for a repairman....
Sep 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse located on a ge spacemaker micro
the fuse is located in the back close to the power transformer you have to take off the cover to get to the fuse.good luck
Feb 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave
yes there is. the fuse should be located behind the vent grill on the right side above the control panel. there may be a metal "grate" covering the access to it
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
370 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
