Question about Philips 50FD9955 50 in. HDTV-Ready Plasma Television
Menu keeps showing on my TV
I turn the TV on and the Menu pops up , I click on the menu button to close it, but it comes right back up, it is a 50 inch phillips plasma (AMBILIGHT)
  • demayo04 Dec 01, 2008
    Thank you, I was able to upload and download the software my self, and it took care of the problem (just as you mentioned it) SOFTWARE UPGRADE.
    Thanks again
  • karmann_brad Mar 01, 2009
    the menu screen problem on myphilips 42" is the same. where and how does the download work to fix this problem?
  • 106 Answers
Your tv needs a software upgrade. This is usually done by a qulified service technician.
Posted on Nov 26, 2008
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
My lg 42pc1da shows bad color on the right and black smears on the left
Before you toss your TV into the dumpster, have you tried resetting the unit to factory settings?
First, you can go into "Expert mode" on the tv by holding down the menu button. After the regular menu button pops up, keep holding down the menu button for another 5 or 6 seconds until the 4 digit lock code entry window appears. Enter the code 8741 to enter expert mode. Here you can change all the expert calibration settings and restore the set back to default factory settings.
Feb 28, 2011 | LG 42PC1DA 42 in. Plasma HDTV
When I hit the bottom left hand MS Icon to bring up list of programs to launch the list on the right hand black column list my main file areas such as 'Pictures' and used to list 'Documents' but for some...
Click the start menu button so it opens up the menu where the documents used to be, then right click on the start menu. Click properties a pop up should open up saying taskbar and start menu properties. Click the start menu tab, if your not already on it. Then click the customize button. It should open up another pop up saying customize start menu. Then click use default settings button near the bottom of the pop up or you can click the check box under the documents that says display as a link. After doing all that click ok on the pop up it should close. Then click apply and ok on the other pop up it should then close that. Then click the start button and it should show your documents. If you need more help comment and ill try again. If i helped please leave me a rating.
Jan 14, 2010 | Microsoft Windows Vista Ultimate Edition
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Philips 50FD9955 50 in. HDTV-Ready Plasma Television Logo
401 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
