Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
No graba y dice casset defectuoso y compre una y sigue lo mismo
Hola, compre un casset nuevo y sigue lo mismo, sera la calidad del caset es panasonic y la camara es SHARP VL-Z1. es comun en estas camaras? sera que tiene solucion?, porque si tiene un caset nuevo y dice "EJECT THE CASSETTE", grabo un pedazo para ver si graba pero sale la pantalla azul y sale "EJECT THE CASSETTE", porque?.
le agradesco su respuesta. atte alex vargas
  • Tony Parsons
    Tony Parsons Sep 05, 2017
    The convention on Fixya is that all queries and responses are posted in English. Please translate and repost.
  • 169 Answers
SOURCE: sharp viewcam vl z1
there are mechanical problem of your camera...may be one of the motor is stuck up...check the drum motor if free wheeling..is it the common problem of that model
Posted on Aug 25, 2007
  • 64 Answers
SOURCE: Sharp camcorder vl-wd450
something is wrong with the m-chassis needs repair sorry the chassis on any cameras are very sensitive and they break alot not yor fault.
Posted on Nov 19, 2007
SOURCE: HOLA
Ya revisaste que el "candado" este abierto? es decir esta un seguro que no permite sacar copias si lo movieron
Posted on Aug 19, 2008
SOURCE: The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Posted on May 12, 2009
SOURCE: necesito saber el numero de fly back de un sharp modelo 25f m50
f0008mezz
Posted on Oct 11, 2009
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
Mi MP828-8G DEJO DE FUNCIONAR A UNOS DIAS DE COMPRARLO
YO TAMBIEN TENGO UN PROBLEMA CON EL MISMO REPRODUCTOR NADA MAS QUE ES CON LA REPRODUCCION ALETORIA E IGUAL LO COMPRE EN COOPEL, ME LO CAMBIARON PERO SALIO IGUAL Y NO ME PUEDO COMUNICAR CON EL PROVEDOR, YA LO SOLUSIONASTE TU PROBLEMA?
May 31, 2012 | Coby MP828 MP3 Player
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Mi saturn es un sl 2001 pero se acelera mucho cuando llego aun alto ke pueda ser le acabo de dar servicio a inyectores
tengo un saturn sl1 automatico primero se aceleraba y lo lleve a un taller y dijeron que ocupaba una limpieza de inyectores pero le movieron algo para que revolucionara menos y entonces despues se empezo a celentar y tiraba el antifrezee y le compre el tanque de reserba de agua nuevo y siguio igual despues le puse la pompa del agua nueva y sigue igual despues le cancele el heather y sigue igual y le deje el thermostato directo y el ventilador directo y sigue igual que sera lo que tiene?
Feb 14, 2011 | 2000 Saturn SL
No funciona solo aparece ecipse y es todo
A mí me pasa lo mismo y lamentablemente nadie aporta una solución, el mío (Eclipse 180 8GB)se ha quedado trabado en la pantalla azul de inicio con el logo "Eclipse" y no sé que hacer. Un tipo en las respuestas en idioma inglés dice que llamó al número de atención al cliente y le dijeron que dejara que la batería descargara por completo y luego presionara por unos 30 segundos el botón "Play" (me imagino que es el botón del centro, supuestamente es la manera de resetear el player) antes de conectar el USB al PC. No sé si funciona. Mi problema empezó por una canción que no tocaba bien y reinicié el aparato, y puse de nuevo la misma canción y luego se puso el logo azul en la pantalla y éste no se quitaba a menos de mover el switch a OFF, lo pase nuevamente a ON para que descargara por completo, pero ya no lo reconoce la PC y pide drivers, se queda congelado en el logo, ni carga, ni nada.
He visto que muchas personas tienen el mismo problema y todavía no aparece ninguna solución, tú post es el primero que leo en español. Dicen que será un problema de firmware, pero no venía con un CD de drivers o una herramienta para estos casos, la empresa Mach Speed parece que todavía no tiene una página de soporte implementada para este modelo "Eclipse", también no sé como destaparlo, pues la tapa es una sola pieza. Si sabes como solucionar tu problema, házmelo saber por este medio. Talvez es de esperar, porque el firmware que tiene mi player era de septiembre del año pasado y lo compré en noviembre, el precio es bajo, pero no es posible que nos tomen el pelo de esta manera.
Feb 10, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
GR-DX75US
Hola Lucio
Yo sot de Argentina y me pasó lo mismo que a vos, llamé a representante en Argentina y me dicen que ellos no lo pueden arreglar porque la camara fue comprada afuera de Argentina, esto es una locura ya que en todo el mundo las están arreglando gratis. Decime como hiciste si es que lograste solucionar el problema
Saludos
Nov 15, 2007 | JVC Cybercam GR-DX75 Mini DV Digital...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
46 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
