Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Lack of suction
I have a sears performance machine - new clean bag and filter - power but performance light comes on with no suction - How can I clean out the hose with electrical components inside? am assuming I have a clog somewhere.... thanks
I use a broom handle..works very well
Posted on Nov 29, 2008
Why is suction substantially reduced?
blockage in the suction line
if it is the wet mode there should be a valve (ball) that sucks up to stop water from getting to the motor when the receiver is too full. If you are in wet mode and still have the dust bag in place then the bag will be a solid block of mud and that will be the blockage.
May 21, 2015 | Craftsman 17765 Canister Wet/Dry Vacuum
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
There is a suction problem - the suction power is very low. The filter has been washed, dried and replaced but the problem is still there What is the problem? Thanks.
Something between the bag and the suction opening is clogging the vacuum. Start at the bag. Remove the bag and check for a clog. Remove the hose from the back and check for clog. Release the handle and turn the machine over to expose the sweeper bush. Check for clog. If you haven't found the clog at this point, remove the 4 screws on the brush cover. Then remove the brush and check the hose going into the machine. If the filters are clean the machine should have plenty of suction.
Nov 27, 2010 | Hoover Vacuums
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Red light on top is on
If you have something like a metal ball, drop it down one end of the hose to see if it comes out the other side. The hose, wands or the inlet in the power head, if any of these have a clog, that red light comes on and suction is low.
Oct 24, 2007 | Kenmore 25512/ 25513 Progressive Canister...
Performance indicator light
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
128 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
