Question about Onkyo M-282 2-Channel Amplifier
I am totally new to this hooking up a receiver to a amp.
I am DJ needing to be mobile. Not sure what to do I have all this equipment, I don't know how to hook it all up so it functions properly. I have a onkyo receiver and a amp. The receiver can't handle the sound from the mixer and cd players so I bought the amp(Onkyo M-282 2-Channel Amplifier) not at all sure on how to get it all to work.
Trying to record music from my dj equipment not sure how to connect
out put from the dj stuff to the input lines on the amp your using to record on, once the CD or tape, or whatever your recording onto, is set to record, it should pick it right up , now if your doing all of this off your DJ equipment everything that's used, from record players, to CD to tape, will be run through the main amp your using, if the selection switch is set to whatever, you should be able to just turn on the unit your recording to, and it will pick it up , everything leading to the main amp will be plugged into, a line in, and some, ( tape player ) will also have a line out, ( so should the cd player if its a recordable one, which in turn would be supplying the lines output to each unit .
Jul 25, 2011 | Audio Players & Recorders
How to hook up 18"
Hello!
SO I am going to give you more of a signal layout from the turntables (or whatever you use to DJ) to the speakers.
Turn tables-> Mixer-> Eq-> Amp-> Sub and other speakers.
The part that I am not understanding is why do you need the QSC amp if you have a powered sub? The powered part of that means that there is a built in amp, which eliminates the need for the QSC amp unless you are sending that sound to main (non sub) speakers.
Hope that helps!
May 03, 2011 | Audio Players & Recorders
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
How do I up Receiver/EQ/Amp?
In the order you state them.
Receiver, EQ, Amplifier,
These graphic eq's and the amplifiers are pin 2 hot on the XLR by default (which is the norm) unlike some other makes. Handy to know when making up cables from receivers like this.
Mar 23, 2009 | Audio Players & Recorders
Akai PX-E855K turntable - switchable pre-amp - how?
To my knowledge this is no switchable pre-amp on this unit. Just connect to your own phono pre-amp and you should be ok.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 15, 2009 | Audio Players & Recorders
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
Cofig ion icue to virtual dj 4.2
It is a little difficult, and more complicated for me to explain here. Your best bet is to hit youtube, and do a search for ICUE Instructions. There are PLENTY of videos out there.
- OPTiC
DJ Equipment Repair
DJ Equipment Sales
Numark Parts
Jun 29, 2008 | Numark Fusion 494 Complete DJ Package
Onkyo M-282 2-Channel Amplifier Logo
735 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
