Question about Concept CC-452 Car Audio Amplifier
Why does the protect light turn on when i connect the RCA wire?
Why does it do that?
  • hartgarman May 15, 2009
    my amp was working fine then just stopped and the protection light is on. I checked all the wiring and everything seems to be fine. how do i get it out of protection mode?
Check the fuses an make sure nothing is grounding off the amp which will make it go into protect mode
Posted on Nov 30, 2008
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Kenwood kac-749s amp power indicator flashing red. what does this mean and what can fix it?
Either there is a short in the in the amp or hopefully just the speakers or wires going to the amp. disconnect any speaker input output and turn your amp back on(you will only have power, ground, and remote wires plugged in at this time) and if the red protect light goes away, then there is a problem with the input/output speaker wires, this includes your RCA's. If it's still flashing red then there may be a stray wire shorting to the amp in the speaker outs, other than that your amp may be fried. By the way, if it works without any speakers connected, including RCA's try connecting one component speaker at a time starting with your RCA's(if using them), speaker in, then speaker outs. If it turns into protect mode, note which speaker/RCA it was and replace or repair the short.
Jul 11, 2011 | Kenwood Car Audio & Video
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
The portection light on my alpine mrv-1507 wont let me get any sound
remove the rca wires and the speaker output wires and just leave the 12volt power/ remote/ and ground connected. turn on the radio and see if the light goes off. if it does then one of your speaker or rca wires are shorted, plug in one at a time and see which one gets you the red protect light, then find the short for that speaker/rca wire. if the red light turns on with only the 12volts/remote/ground, then the short is in the amp.
Feb 26, 2010 | Ohm Crystal Mobile Sound CADT 600.2...
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
Kicker zr360 in protection
unplug rca,disconnect spker turn on amp if light goes away start connecting with one rca and one spk wire and you will find the problem should go away '''''''make spk polarity is wright
Apr 07, 2009 | Kicker ZR360 Car Audio Amplifier
Protection Light Is Coming On
You say the protection mode only occurs when you plug the RCA's in. Does it have to be both RCAs or just one?
The other end of the RCA cable is plugged into the HU?
It possible the RCAs have too much DC voltage on them, causing the amp to go into protection.
Is there a short in the RCA cable?
I would definitely check out the RCA connection at the back of the HU, as it sounds like there could be other issues there. Make sure the RCA connectors aren't touching any other metal (especially +12V).
Mar 14, 2008 | Car Audio & Video
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Jan 08, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Concept CC-452 Car Audio Amplifier Logo
130 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
