Question about Nintendo Wii Console
I erased data user information
I bought Wii from original owner and whe I erased data user information, the remote stop working, all I get is flashing lights. How do I get it to work again!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
There is a button behind the front panel on the Wii, and a red button behind the battery cover on the remote.
With batteries in the remote, push the red button on the remote.
The LEDs will blink.
On the Wii, push the sync button behind the SD card front cover.
When the blinking on the remote stops, it is synchronized.
The LED that is lit is the player number.
Use this method for any more remotes you want to add.
Posted on Nov 26, 2008
Wii nintendo bought used how do i reset it
Method One: The Soft Reset The soft reset is the easiest way to reset the Wii, and the least intrusive. There are two ways to perform the soft reset, either using the Wii remote or the button on the console.
To reset the Wii using the Wii remote, begin by pressing the home button (the small button with a house on it). This will bring up a menu screen. Next, move the cursor to the button labeled "Reset" on the screen. Press the "A" button on the remote to select the reset option. This will reset the system.
If the Wii remote is not responding, users can also reset the Wii using the button on the main console. First, locate the button labeled "Reset"--it's on the front of the console, beneath the "Power" button. Press and hold the "Reset" button for two seconds, then release the button. This should reset the system. Users should remember that resetting the Wii will shut down any running programs immediately and destroy any unsaved data, so only reset the Wii if it is causing problems. However, resetting the Wii will not alter any information stored on SD cards.
Method Two: The Hard Reset If the soft reset doesn't fix the Wii, users can also perform what's known as a "hard reset." A hard reset involves disconnecting the Wii's power supply and must be done manually--there are no pre-programmed buttons on the Wii that will perform the hard reset.
To begin the hard reset, find the "Reset" button on the front of the console. Press it for two seconds, then release (this performs a soft reset on the device). Next, press and hold the "Power" button. Continue holding this button until the light in the button switches from green to red--this means that the Wii console has shut down. Now, unplug the AC power adapter cord from the wall outlet or surge protector as well as from the console itself. Allow the Wii to remain like this for five minutes.
Once five minutes have passed, plug the AC power adapter cord back into the console, then connect the other end of the cord to an AC outlet. Press the "Power" button to turn the Wii on. The system should now be running smoothly.
Method Three: Reset Factory Controls Sometimes, Wii users might want to return the system to its original, factory-shipped status and remove any personal data. Nintendo especially recommends doing this before selling or gifting a used Wii to someone else. To perform a factory reset, also known as formatting the system memory, go to the Wii menu and select the "Wii" button, then select "Wii settings." Click on the blue arrow on the right-hand side--this will bring users to a page called "Wii System Settings 3." Select the option labeled "Format Wii System Memory," entering the parental controls PIN if requested. Finally, select "Format" to complete the factory reset. This will remove all hard-drive data from the Wii, and such data cannot be recovered, so users should only perform a factory reset if they're sure they want to do so.
Jan 30, 2017 | Nintendo Video Game Consoles & Games
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
How can i reset the wii i have the chip in and the hack but some of the new games they playfor about 10 min and then stop freez compleetly how can I FORMAT THE WII
Format (Erase) Wii System Memory
This option is used to delete ALL Channels and ALL save data that have been added to the Wii console and will wipe the system memory clean, as it was when purchased new. Please note that if you also have a Wii Shop Account, that data should be deleted first:
To clear information from the Wii Shop Channel, including records of your transactions and rights to download software:
  1. Access the Wii Shop Channel. Select "Settings" from the list of options.
  2. Select "Remove Wii Shop Channel Account." Once completed, all information will be erased.
To delete ALL Channels and save data :
  1. Access the Wii System Settings screen.
  2. Click on the left blue arrow twice to reach the Wii System Settings 3 menu options.
  3. Select "Format Wii System Memory." If Parental Controls are set, enter the PIN.
  4. If you are sure you want to erase the Wii console's system memory, select "Format."
This option will erase your HBC and Neogamma channel too, if you have softmod..
Hopefully this help.
Jan 18, 2010 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Problem with my Wii remote
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Dec 11, 2008 | Nintendo Wii Console
I erased the user data information, because I bought console from original person, and now when I erased it, the remote doesnt work. How do I get it to work..
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii.
----John
Nov 26, 2008 | Nintendo Wii Console
Wii remotes not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
May 10, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
