Question about Sony Playstation 3 (PS3) Console
PS3 won't update games
I put in one of my games and it says, " latest update for this software has been found." so i start to download it, but like 7% through it freezes and says, "an error occurred during the download the download operation." I don't know whats wrong, can someone please help me? =(
  • 1 more comment
  • tacoe32 Dec 08, 2008
    i have the same problem do i need a new hardrive
  • S381 Jan 02, 2009
    I have the same problem, I am wondering if it is the router settings or something. It works fine with the system updates and playstation store.
  • SWE XinzatyAMP
    SWE XinzatyAMP Sep 04, 2013
    it's the router but i tried to see if it works if i turn off the router and the start it again but it does not work :/ so there is something else, Help!
I found a solution that fixed the problem for me on the playstation.com blogs. http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&message.id=128436&query.id=845#M128436
Go to your router's setup page usually 192.168.1.1 and go the the ADMINISTRATION tab and check the option disable UPnP.
Posted on Jan 02, 2009
  • 344 Answers
This could be a problem with your hard drive or just a slow internet connection. If using wireless, move you ps3 a bit closer to the router and make sure the router is higher then the PS3. I that still doesn't work then try a different hard drive. Hope this helps. Thanks,
Posted on Nov 26, 2008
Go into settings and disable media server the same thing happend to me but now it's working
Posted on Sep 16, 2012
  • 79 Answers
SOURCE: Problem with update install
download the update to flash drive using your pc then plug it into your ps3 and install it that way.(may take 2 or 3 trys).
Posted on Apr 09, 2009
SOURCE: ps3 update data version 1.02 wont download to play
Delete all game data then turn off media servers. It will then download the update
Posted on Dec 31, 2009
walesarumi
  • 6993 Answers
SOURCE: my ps3 says error occured during operation
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down.
If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on.
Check if there's any loose cables. If there is, put them back in.
If the freezing continues after taking the above step, you can follow the link below as a guide on how to fix the problem.
http://www.squidoo.com/PS3-Repair-Guide
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Posted on Mar 23, 2010
  • 139 Answers
SOURCE: ps3 update operationhad an error
Should be in the fuse box or next to it.
Posted on Aug 01, 2009
  • 110 Answers
SOURCE: ps3 says a technical error has occured during
that happens to me on every update but what you have to do is be patient and try it a few times untill it does it all and i would recommend doing it during the night when your sleeping can get very boring during the day
Posted on Jan 09, 2011
How can I fix 8002F334 error in my ps3
I've seen this error code going around for the older PS3's. From what I can gather, it's a HDD issue that can't be cured easily. Here are the steps to take that I found, that seem to work for all PS3 systems.
  • take out the hard drive
  • connect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)
  • open up disk management - in win7 it asked me to make a master boot record, so I did.
  • format in NTSF - that's right, NTSF - don't use quick format
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop-up saying the hard disk have to be formatted
  • hold start + Select for 5 sec.
  • After formatting the system will restart and the update will start installing
  • configure your ps3 setup - done
  • Remember to get the latest firmware from SONY onto the USB drive.
Jan 12, 2016 | Video Game Consoles & Games
My PS3 have error code 8002f334
  • boot ps3
Sep 05, 2015 | Sony Playstation 3 (PS3) Console
Ps3 won't update
  • If you are attempting to perform a system software update via a game disc, ensure that the disc is clean and free from dirt, marks or scratches.
  • If you are attempting to perform a system software update via an external storage device, download the system software update data again. If the problem persists, attempt to perform the operation using a different external storage device.
  • If you are attempting to perform a system software update via the Internet, attempt to perform the operation again.
  • If the problem persists, restart the PS3 system and attempt to perform the system software update again.
  • If the problem persists, visit eu.playstation.com/contact to contact Customer Support.
  • Hope this helps!!!!!!!!
Mar 08, 2013 | Video Game Consoles & Games
I had to download the latest update. got to 35% then came up with 8002F165. it won'let me go to the home menu. please help:(
it means the firmware file that you are trying to install on the ps3 is corrupted. you need to redownload it and attempt to update again.
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
Downloading software update for a game and system froze, TV screen went dark. System will not turn off. What do we do now?
Go here
http://community.us.playstation.com/thread/627262?start=0&tstart=0
once you complete the steps go to option 6
download the latest update file in ps3.com
and install the update with USB
Done :)
Thanks
www.1RepairStop.com
We Fix Everything
Sep 03, 2011 | Sony Playstation 3 (PS3) Console
I purchased Transformers 2 Blu ray and when I put it in to play, the PS3 said I needed a system software update. I am not internet capable on the PS3. What do I have to do?
you need the internet to be able to get the update so if you have a PC with the net that will do and u will also need a flash drive, just go to google and type in latest PS3 update and find a download for it after you download the update type into google how to update ps3 with a flash drive that will tell you everything you need to do
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 stuck in demonstration mode 2.80
Visit the Playstation3 website and download the lastest version onto a flash drive. Making sure you dont have any other software/files on the flash drive.
Create a folder on the flash drive in which to save the update data.
Using a PC, create a folder named “PS3” on the flash drive or USB device. Within the PS3 folder, create a folder named “UPDATE”.
Install the playstation update into that folder. "PS3UPDAT.PUP"
Your console SHOULD now reconise the update.
If nothing changes restore the playstation fully to its default status.
Jul 28, 2009 | Sony Video Game Consoles & Games
Not playing any game
Are you connected to the internet with your PS3? If you are make sure you have the latest update. If not you can download the latest update onto a memory stick via your PC and just plug it in to the PS3
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
PS3
Ps3 supports over 1000 ps1 and ps2 titles. Make sure you hook your ps3 up to the internet and download the latest firmware updates. Odds are your system will be able to play all or most of your ps2 games once you update the ps3 online.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
10,080 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
