Question about Samsung Cameras
S630 camera..says low battery ,even with new batteries
    Sergeant:
    Champion:
  • 248 Answers
This is a connections problem you might want to tighten the battery pack or batteries to be able to get good power.
Posted on Nov 26, 2008
Even when I add new batteries it says batteries low and won't work. Why not?
the normal battery is not recommended,
please use a re-chargeable Ni Cd or equal battery with a 2500 MA or higher. will work properly.
Nov 13, 2015 | Samsung S630 Digital Camera
Can put in new batteries and turn on and it will say batteries are low and shut off
Pls refer to the camera manual. check the battery type. use batteries that is recommended by the manufacturer.
Jan 07, 2011 | Samsung Digimax S630 Digital Camera
It will not let the lenses come out.i put new batteries in it,but it still says low batterery.
you need to use at the least alkaline batteries in your camera. as most digital cameras "eat" batteries i recommend rechargables. i tried dollar store batteries once in my camera and managed to get one or two pictures (if it even started up).
robert
please take a moment to rate this solution thanks
Nov 30, 2009 | Samsung Digimax S630 Digital Camera
S630 screen not working
i knoww cus i had took pictures on firday at dha skatinq rink with my freinds dhen saturday my camera wasnt workinq so then i decided to buy some new batteries, i bouqht some new batteries on monday & quess what it wouldnt stay on,! like it came on for like 5 sec dhen it shut off , i f**kinq hate dhat camera. !
Aug 07, 2009 | Samsung S630 Digital Camera
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
You might want to try cleaning the battery contacts in the camera. I usually use a q-tip and rubbing alcohol (not too much, just moisten the tip a little). After doing so, blow in to the camera a couple of times to remove any leftover q-tip fibers and/or alcohol. This happens to me all of the time - the contacts can get a little corrosion/patina on them (even new after manufacturing and storage) that is hardly visible. Good luck.
Jan 11, 2018 | Pentax Optio M30 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Problem in s630 digital camera
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set- Up 2
- Select Battery Type
Under Battery Type there are two options:
- Alkaline- if you are using non- rechargeable batteries
- NiMH- if you are using rechargeable batteries
Nov 19, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
128 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
