Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Flashing on and off
Hello i have a 20" 2005fpw dell monitor i had it for 2 years until it started flickering on and off, when i boot up the computer its fine when ime running applications or on the internet for about 4 minutes it starts flashing on and off, speacialy when ime online the screen starts to flicker even faster when ime surfing the internet but you can still see the screen but its anoying flickering makes me turn the monitor off for about 2 minutes and then turn it on again it stops flickering but about 4 minutes later its back to its crazy flickering. does anybody have good solution for me on what to do.
  • Anonymous Mar 19, 2014
    Hi, I have a KDS 468p monitor, it worked awesome until yesterday. This morning I pressed the button to turn it on and it just started flickering the power light and the screen, and it makes a little click too, like from the speakers or something. Is there anyway to fix it?
I had this problem with my Dell 2005FPW as well, it was the inverter, i ordered the part for around $60 after S&H and installed it at home.
Posted on Jan 30, 2008
  • 9,098 Answers
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Posted on Jan 12, 2007
My dell 1720 will start to boot, the hard drive light flickers about 6 time then stops. the backlight comes on and then laptop does nothing else
Your problem may be the video card. Also, download Hirens Boot CD( google it) and burn the iso onto a CD. Then plop it into your machine, and hit F8. See if it boots that up.
Aug 22, 2010 | Dell Inspiron 1720 Notebook
My computer screen flickers when you start it up what could it be
It is normal to flicker if the computer is turned on (on a cold boot), but there could be a problem on it if it keeps on flickering inside the operating system.
Dec 14, 2009 | Dell E207WFP LCD Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
I was given a dell 2005fpw screen by a friend and im not sure if i've damaged it. When you plug it in to the mains and turn it on it comes up with the dell screen but after that the screen flickers and im...
if the screen is flickering it could be a bad monitor. Try hooking up another known good working one if you can. If the known good working monitor works then you know the dell monitor you were given is bad. If you get the same flickering result then make sure you wait until your laptop boots up into windows then try to change the output to the monitor. If you can get a picture then try the other monitor to see if you can get a picture as well.
If you can get pictures with both monitors then you know it was a matter of changing the output on the laptop if you get a picture on one but not the other then you know one of the monitors is bad. Depending on the laptop you have will depend on what key combination is used to change the video output to the monitor.
Aug 03, 2009 | Dell Computers & Internet
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
LCD monitor turns off after 2 seconds from boot
Try to see the video card and fell if it is hot, if the fan is running when turn on. There is a part of your computer that is hot, that when reach to that temperature it trun blank or off.
Thanks
Nov 19, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
720 people viewed this question
Alun Cox
