Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
HV splitter block bad
Does anyone know the part number or where I can purchase this part?
THX
  • cviola2006 Nov 26, 2008
    Thank you so much so it is really called the Block Assy? I had a repair man tell me that I need a HV Splitter. I called Sony and they do not know what the HV splitter is. Is is the Block Assy and do you think I can install myself?
    Thanks
  • 2,323 Answers
If you have the RA-6A chassis, you can find the part if you go to this website.
Posted on Nov 26, 2008
  • Jaime Hernandez Nov 26, 2008
    If you intend to DIY, I would suggest be very careful because of the high voltages around the area where this Block Assy is. Before removing the old part make sure you unplug the TV from the main AC power.
    Good Luck.
When testing the hv flyback by turning on the tv, if tv stays on the hv splitter block is bad ,but what if tv turns off what you check next? thanks for the help.
first, I think you have this backwards----if splitter disconnected (look for physical signs or arcing or it burnt) the High voltage would come up and sizzle where it connects to the splitter.
If the set with the splitter disconnected still shuts down it is not the issue---got a D52 of some kind?
Nov 02, 2012 | RCA Televison & Video
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi, I am trying to purchase a hi voltage splitter for this set and cant seem to lock down any part number or where to get it, the number on the part reads 1517923 I am figuring this is bad cause when I try...
if it is a black rectangular block it it the HV splitter.
Try SUBURBAN ELECTRONICS; they have a online catalog and also sell on EBAY as the seller
sewsales55
SD TECH
May 13, 2011 | Proscan PS52810 52" Rear Projection...
SMELLING, HISSING AND NOT TURNING ON....
Whenever there is a a spark or a flash it generally means high votage(HV) is arching either from the flyback, one of the CRT's or HV splitter/Focus block where the HV is created - It will be easy to diagnose but probably expensive to repair. Parts costs- Flyback and HV block $100-200 and CRT over $300
Sep 20, 2009 | Zenith R57W46 57" Rear Projection...
I have a rca p52939 that won't turn on.
Failure of the HV splitter was a very common problem when I was doing these big screens on the road. The set won't come on if the splitter shorts. We used to test if that was the cause by pulling the HV input lead out of the splitter (leaving it still inside the plastic cup so it wouldn't arc anywhere) and turning the set on. Most often the set would fire right up (without picture of course).
I believe the RCA part number for the splitter is 205064, and it's available from a number of sources. I'm not home right now so I can't check. If I have the number wrong I'll post a follow-up comment.
Feb 13, 2009 | RCA P52939 52" Rear Projection Television
Hi. Quick question.
Jerry,
I am assuming you need to get the HV lead out to remove the board. That model if I am not mistaken has the one large Red HV lead running from the flyback to the HV splitter where the other 3 large wires run to the CRts. If this is the case the trick is to remove the wire from the flyback at the splitter, I have found its easiest to slide the red rubber boot back then use a pair of pliers with tape on the jaws so as to not hurt the wire then grab the wire as close to the splitter block as possible then using a second pair of pliers like a hammer and hit the pliers holding the HV lead and thst will force the HV cable out of the Splitter block.
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Was working fine for 6 years until it just sparks at the HV Splitter Box. Is it a bad splitter box? and if so where can I get a new one?
YOU HAVE A CRACKED HV SPLITTER--THIS IS NOT A REAL EASY JOB--GO TO YOUR LOCAL TV SERVIC COMPANY --YOU WILL NEED THE MODEL AND CHASSIS #'S ,,THERE IS ALSO A PART # ON THE BLOCK--PRICE SHOULD BE 75.00 OR LESS-GOOD LIUCK!!!!!!!!
Mar 22, 2008 | GE 46GW945 46" Rear Projection Television
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
Feb 09, 2008 | RCA HD52W140 52" Rear Projection...
My RCA Rear Projection TV Has Sound but no picture.
The tiny lites you see on the end of the tubes or crts are the filiments. This is a normal thing and if you didnt see those I WOULD BE WORRIED.. Now Who is they ?? who told you all that was wrong with the tv was the HI voltage block?? if your not a tech Dude your traveling into some very ,very dangerous territory!! Do you know I used to know three differant peeps who wanted to fix there own projection tvs BUT they are now all DEAD!!! They all electrocuted themselfs fooling around with the HI voltage circuit same as you did!!! Man You should stop and think what your doing before you treally hurt yourself.. Now for myour problem. How do you know the HI- voltage block was bad??? It wasent if you have the same problem that you started with. You probably have a bad flyback or hi voltage transformer?? Well any who I hope you dont get hurt tinkering with these sets as you can if your not carefull!!! CALL A PRO to assit you. Lifes not worth saving a few bucks for is it?? Good luck
Jun 13, 2006 | RCA P61940 61" Rear Projection Television
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
