Epson stylus photo r300 general error - Office Equipment & Supplies
Hi--I had a BIG problem, day after day, fiddling with my Epson Stylus printer. The "General Error" kept repeating, and the two red buttons flashing each time I turned the printer off and on. There was nothing jammed at all. So, as a last resort I took a paper towel and ran it along the bottom of the inside of the printer (yeah--all technical jargon, I know--not a computer person here :-) and a bunch of black ucky stuff came up. MY PRINTER WORKS NOW! Hope this helps someone else. I saw a lot of posts where people said to throw out the printer and start fresh when my problem happened, but what an easy fix. GOOD LUCK!
Posted on Dec 23, 2008
  • radiocliff Nov 04, 2010
    Wow. It worked! I've been wrestling with this for days and was about to give up. I had to turn it back on and wipe the far right side when the head was over on the left side and kinda hold the head away while I wiped furiously with a paper towel. Lots of black ink on the paper towel. I turned it of and back on and we are back to a green light. Thank you again!
    Problem Solver:
  • 6 Answers
How refill a stylus ink cartridge?
Posted on Nov 26, 2008
ohms
  • 1879 Answers
SOURCE: epson stylus photo R300
>disconnect printer from the computer
>powercycle the printer
>check for obstructions / torn papers inside unit
>if issue still persists - hardware issue
>warranty starts from the DATE OF PURCHASE better check
Posted on Jan 03, 2008
jacklee366
  • 541 Answers
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
you can try and reset the printer with software let me no if you dont haver it
Posted on Nov 18, 2008
eclark317
  • 159 Answers
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
SOURCE: epson stylus r300 priner
when i thurn printer on it says general error see your printer documentation for information about clearing the error
Posted on Feb 19, 2009
  • 9 Answers
SOURCE: My EPSON STYLUS PHOTO R300 printer will not print
5 years sounds just about the time if you used it a lot. take it to service center. if it is the ink drain pad it'll cost up to 80 including job. if it just a counter it will give you another year to use it if they'll reset the counter.
i'd opt for a new one. but if you still have spare ink left then it is worth a try. good luck
Posted on Apr 19, 2009
General error see your printer documentation for information
the best way to overcome this problem is to re-install driver it. the link provided below will take you to the place from where you can get it downloaded -
http://drivers.freesoftz.com/other-driverstools/others/51983-epson-stylus-photo-r300-driver-5.5b.html
Dec 28, 2010 | Epson Stylus Photo R300 InkJet Printer
I just bought an Epson R300 printer on Ebay, and there is a General Error message displayed.
What does the error say?Does it say this:"A printer error has occurred, see documentation"
Apr 26, 2010 | Epson Stylus Photo R300 InkJet Printer
General error and crunch sound epson r300
Your printer's rollers and gears need cleaning and lubrication. You need to bring it to a competent technician.
Jan 12, 2010 | Epson Stylus Photo R300 InkJet Printer
EPSON Stylus Photo R300 software
I dont see a real question here ... so I will put on my swammie hat and guess ....
Swammi says you want software (driver) for the Epson Stylus Photo R300.
www.epson.com/support ... search R300 and get your driver
K
Nov 01, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson printer maintenance 230 General error
General error : head carriage error / chip not recognized. Head carriage can't move freely. Just turn off for about 1 hour, turn on again without ink tank. Plug ink tank.
Jun 12, 2009 | Epson Stylus Photo R300 InkJet Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r300 priner
Dec 22, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson r300 banging noise when switched on
you need to reset your printer. you can pick up a utility called ssc utility. and then reset it
Dec 13, 2007 | Epson Stylus Photo R300 InkJet Printer
1,272 people viewed this question
jasbo
jasbo
