Question about Frigidaire FRS26R4C Side by Side Refrigerator
Water leaking from left side ice/water dispenser
Water is leaking from the bottom of the plastic housing below the dispenser area. Turning the icemaker off seems to resolve the problem until it's turned back on. Icemaker still works fine but water is leaking in the front while it's on.
  • 2 more comments
  • Jay Adams Jan 08, 2007
    I found out how to remove the plastic housing in the front of the door. Found that below the removable tray, it was filled with water. Also see that it appears that water is running straight from the icemaker ice bin and through the ice dispenser valve causing my issue with the water down the front door. I just need to know why the icemaker might be overfilling with water I guess.
  • leeking Dec 29, 2007
    Our icemaker/water dispenser is also leaking. It takes several hours, but it fills the little comparment below the grate and then either overflows out the front, or sloshes out when you open the freezer door.
    I'm not sure if we have the same model of refrigerator, though.
    Lee
  • Anonymous Mar 18, 2014
    We had a power outage after an ice storm. When the power came back on, the icemaker started leaking water.
  • Anonymous Mar 24, 2014
    Bottom freezer
  • 237 Answers
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Posted on Jan 08, 2007
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Water leaking about once a week from french door fridge
Look in back on the bottom left in the area below the compressor at the plastic drain pan. Most likely it's cracked
Jan 03, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRS26R4C Side by Side Refrigerator Logo
247 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
