Question about Microwave Ovens
I purchased a sunbeam coffeemaker in June from Zellars. I didn't start using it until the first week in September. I noticed that it dripped from the coffee grinds holder even when it had finished brewing. Everytime I lifted it from the heat element it dripped coffee on to the element. Also the paper filter folded in about 3 out of 10 times. I then purchased a permanent filter cup thinking this would solve the problem. To no avail. I am also getting more and more coffee sediment in my cup now. I still have my receipt for $45.19. Zellars policy is only 30 days - Can you help me? I would like to have a replacement for this coffee maker - but would hope that this iproblem is not the case for all of your coffee makes ( I have had your brand in the past and have not had this problem.
  • 333 Answers
Contact sunbean customer service. Look on the web for contact numbers. Explain your problem and tell them you have the reciept and have been contacting Zellars but have got no response. So you decided to contact them directly. Almost all the time they will honor your problem.
Posted on Nov 26, 2008
Our Sunbeam model SM15A19W over the range microwave quits after 3 - 4 minutes of use and we have to wait 15 minutes and it comes back on. Is there anything I can replace myself?
Had a similar issue I found the unit was overhaeting and if I ran the air vent while in use it helped cool it is this a non-vented system mine is
Sep 03, 2012 | Sunbeam Microwave Ovens
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
I need a manual for a Sunbeam breadmaker Model 5891. It didn't have a manual with it.
Visit and donwload in this link: man-migrate/MANUAL000063299 (pdf format)
Good luck (remember to rate and comment this answer).
May 17, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
My coffeemaker doesn't brew. it's been working fine for years and now, it just does not brew.
Have you been running a cleaning cycle every other week? Sometimes if you don't use cleaning solution or white vinegar hard water can block up the feeder tube...
Jan 14, 2011 | Microwave Ovens
How much rock salt goes into the sunbeam slush magic?
U need to use more than what the sunbeam book says. I put in about a FULL cup full, layering it between handfulls of regular ice purchased from a bottle shop. Rock salt isnt cheap though , but try to get bulk rock salt from aldi's or somewhere.
Dec 27, 2010 | Sunbeam Microwave Ovens
The microwave starts by itself and does all different things.
the power triac that is the main power controller for power to the microwave is starting to leak from the gate terminal and is firing the triac,just as if you pushed the start button
Sep 08, 2009 | Jenn-Air JMC8130DDS Microwave Oven
Have a new Emerson MW9710W microwave. Had it
My daughter is having the same problem as you are having. Thing is we bought it for her new. She had not used it at all for a year. They finally bought a house, started using it in May. It is now doing the exact things yours is doing. Is there some kind of recall notice on these microwaves or what is wrong and how do we fix it?
Jul 09, 2009 | Emerson Microwave Ovens
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
