F2-64 Content
Toner supply abnormality Detail
When toner near end is detected with the toner supply time of 50% or less.
When the toner supply time exceeds 300%. Cause
ATC sensor abnormality
Toner supply abnormality Check and remedy
Replace the toner cartridge.
Replace the developing unit
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
In order to get at the main rotor gears, you'll have to remove both sets of rotor blades and drop the chassis. After removing the battery cage you should be able to access the two main gears. You don't need to remove the motors, but if you need to access the main gear for the lower-rotor, further dis-assembly is required. I think there's a link to a dis-assembly video for the Exceed models on rcdiscuss
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive a. 10 - 30 watt bulbs b. 20 - 15 watt bulbs c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
I had the similar thing happen to me before on a different game and so I started playing back from the start by the next day I turned it on and everything was back to normal.
I hope this is the case with your issue if so keep us posted
i will see what i can find out more info on this one.
the wireless headseats are hard to connect to the game to the point of why get a wireless headseat. you have to reconnect it every time you wanna play but ne way...after configuring the ps3 (in the settings menu under accessory settings and register bluetooth device) then you have to connect it throught the menus in Warhawk to set up bluetooth then while in waiting area press connect button on headseat. otherwise get wired headseat plug in and go
lool...why do u type ur problems here...all ur problems can be found on playstation.com
anyways....did u check ur NAT....go to network...connection status.....the last thing on that list....if it says type 3....ur using a highly secured internet connection...(firewalled)...and its blocking ashitload of ports...i have warhawk...and i know from what i'v heard...it needs a lot of ports to run
i...thankfully dont have problems with the game
