Were do i insert my cameras memory card in my all in one officejet j5730
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
How to connect a printer to a digital camera?
If the photos are stored on the memory card (SD) in the camera, then remove the memory card from the camera and insert it into the memory slot in the HP printer. You can then print the photos that are stored on the memory card.
Jun 03, 2011 | HP Officejet 6500 Wireless All-in-One...
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
My hp officejet 7210 all in one will not read my SDHC memory card for my new Panasonic camera. Why? Should I purchase just a SD memory card? Will that work?? Thanks
Purchasing an SD card might be better. Just for the fact that when your printer was manufactured the technology for SDHC cards were still not incorporated in your printer.
Feb 06, 2011 | HP Office Equipment & Supplies
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Memory card
memory card is bad, repalce it
Oct 24, 2008 | Vivitar DVR 530 Flash Media Camcorder
HP Officejet Pro L7680 Problem - memory card reader
You should see in "My Computer" a few drives that read "Removable disk". They refer to the memory card slots on the printer. Double click on each one until you find the one that your card is in.
Jun 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
113 people viewed this question
jasbo
jasbo
