Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Will print but not copy or scan
On both copy and scan, the "light wand" seems to be stuck in document feed mode? Get error message 2200
  • loraconnell3 Nov 26, 2008
    won't print. ink cartridges stay to the left of the printer so i cant even remove them has error code2200 on it.
  • 1,011 Answers
click this link to solve your problem
good luck
Posted on Nov 26, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will print from computer but not copy - 'prints' white pcs. of paper from glass or feed but will print from computer light tracks across and back but still prints white when top is open - so I'm thinking...
Your CCD mite be bad. Thats what sees the orginal document. or the cabe between it and the circuit board, take the orginal glass off check the ccd and or cable.
Aug 12, 2009 | Samsung SCX-5115 Fax Machines
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Power off the AIO and remove the power supply from the back of the unit.
Close the top cover, reinsert the power supply, and power on the AIO.
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
It seems like part of the light on the copier has burnt out...can the light be replaced? I get a thick dark streak in a copy or scan but not when I print something. Have replaced ink and aligned...
Light is not burnt out.
Open the feed in section where you feed the documents, and clean the glass that documents are scanned across. It is simply dirty
Mar 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Lost the cd how to install printer to comp again?
plz check the manufacture website for the driver download
Jan 13, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
