Question about Sony PlayStation 2 Slimline Console
Third Censor Broke!!!
I took my ps2 slim apart to block the third censor right next to th laser
& i ended up breaking of the censor piece so i put it all back t geather
& when i turn it on on the disk does not spin & the laser wont move???
please help beceause i need to fix my ps2 slim asap!
  • 23 Answers
Replase motor and ribben and get a lenz off ebay
Posted on Dec 07, 2008
The windows wont go up on my 1996 buick park avenue i need to know where the fuse for the window is and other possible problems
I have an '03 buick regal and I've had window regulator problems, as many other buick owners have. After the third regulator breaking, and close inspection of broken pieces, every regulator failed and broke in the same identical spot. The weak part is on the regulator guide where the end cables connect in a plastic "housing". On my latest replacement regulator, before installing I made a small re-inforcement piece out of aluminum to back up the weak plastic piece. I've had no problems or breakage since. So I also took apart the other 3 window regulators and upgraded them before they broke...again.
Aug 20, 2011 | 1996 Buick Park Avenue
Ps2 slim disk wont spin and it doesnt read anything it just says there is no data
yes you have a bad laser pick up censor . now you can try to clean the laser by open the unit or buy the laser (pick up censor) and replace i have fix many of this unit and by cleaning never work tha price on the part $50 to take it to a repair shop may be to fix it $90
Feb 02, 2011 | Sony PlayStation 2 Slimline Console
How do i fix my third door on a 150 Ford truck?
He Just took it all apart and found a broken part! Off to the Ford Dealer to get the little piece that broke.
Jan 12, 2009 | 1997 Ford F150 Regular Cab
Clicking noise, PLEASE HELP!!! PLEASE!!!
That happend to me. All i did was move the piece that holds the laser right down by the part that holds the disc and it worked fine then..
Jul 12, 2008 | Sony PlayStation 2 Slimline Console
Ps2 disk spinner won't spinn
my disk stopped spinning on my playstation 2 slim so how do i fix it
Apr 08, 2008 | Sony PlayStation 2 Slimline Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Disk Error...Grinding sound when i put it in
I think you will also have trouble with reading Audio CDs. This is s sign that your Laser is dirty. The following procedure is for the older Big PS2. It will not work for the Slim PS2 model. Do not ever use Alcohol on the Slim models Laser Lens.
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Playstatiion 2 repair
Hi Jaybs,
The disc will not spin if the laser canot read the disc. you may have a dead laser or bad ribbon cable that runs from the Laser to the motherboard. I am posting a procedure to clean the lasers lens. I hope you do not have the Slim model, as this procedure is for the older Big size PS2. You do not use Alcohol on the lens of a Slim PS2 ,it tends to haze over the lens.
Play Station 2 Slim Model
Its called a spindle and you might have to replace the whole spindle motor assembly. Search online for one, there are loads of sites selling PS2 part (make sure you get the right model number or your new part might not work).
Alternately, if there are any computer/electronics fairs in your area you could try there. I needed a spindle motor for a scrap machine I was refurbing a few months ago and bought one from a computer fair for £2.
Here is a video tutorial on how to take your PS2 apart to replace the bit.
http://www.youtube.com/watch?v=izY7pth8vKI
Dec 01, 2007 | Sony PlayStation 2 Slimline Console
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
