Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Frequent cycle times on my home furnace
My forced hot air furnace turns on and off every 10 minutes, (on for 10, off for 10) in order to maintain the temperature, but driving up by gas bills. Yet if I manually turn the thermostat on for 10, and off for 25, I can still maintain the same temp. I am not actually losing heat as fast as I add it. So I'm thinking I have a faulty thermostat??? Also it may be the location of it - it is at the base of the staircase leading upstairs and while that is an inside wall, it is the same wall as the staircase leading up from the basement which is not heated. Could this be wreaking havoc with "perceived" temperature swings sensed by the thermostat? Help!
  • jason_bruno Nov 26, 2008
    My thermostat is a digital one. Would it still have a heat anticipator, or is that only for mechanical thermostats?
    Problem Solver:
  • 11 Answers
There are a few things that can cause this problem. The most common is the hole behind the thermostat for the wiring was not covered up when the thermostat was installed. The thermostat will sense the air in the wall space or the basement if it is open to the back of the wall supporting the thermostat. Turn off the power to the air conditioner if attached and the furnace, remove the thermostat from the wall and seal up the wiring hole with duct tape. Insure the thermostat is mounted level when reinstalled. The thermostat should be mounted to sense the return air to the furnace, if the stair well leads upstairs, warm air rises, so keep the upstairs close to the same temperature as down stairs or move the thermostat and install a door to block air movement to the upstairs. There is a heat anticipator on the thermostat, the setting for it is in the installation manuel. For most gas furnaces it is .8. It is very easy to short out the thermostat when making this adjustment, so always have the power off.
Posted on Nov 26, 2008
  • rgypsees Nov 26, 2008
    Some digital s have the adjustment in the back of the unit, some are programmable, some are fixed and come with the furnace preset. Another problem that is very common is the high temperature cutout in the furnace. This is a sensor that is sometimes dual purpose. It senses heat when the furnace has started and starts the fan motor. Some also shut the furnace down on high temperature. Some of these devices use full system voltage- 120/240 and some use step down voltage of 24-28. Always turn off all of the voltage to the furnace before taking off the cover to inspect it. The sensor is usually mounted to the inside wall of the furnace where it can sense furnace air temperature. Sometimes these switches stick, usually preventing the fan from coming on. A hand slap on the side of the furnace will sometimes get it to work and will work the whole season, sometimes not.. A common problem with this switch, is not the switch, but a clogged air filter or a clogged evaporator coil or something else preventing proper airflow, such as shutting off registers in unused rooms etc..Good luck, need to go work with a horse...
    As an after thought, just turning off the power is not good enough, always test any circuit before you touch it even if you think you have turned off the power, it hurts, been there done that. So be careful!!
After installing this thermostat on my home heating system, it cycles as should, but furnace kicks back in after a minute or less.
if furnace comes back on in less than a minute , How does it maintain a constant temperature ? or does it ?
Jan 18, 2016 | Heating & Cooling
The heater runs for a few minutes and then it turns itself off it's on stable ground and everything
My furnace keeps shutting off, only runs for about 5-10 mins ...
? 5:19
https://www.youtube.com/watch?v=pEng9mtBtKk
Dec 15, 2013 - Uploaded by shannon122005
My furnace shuts off before reaching the set temperature on the... and then i turn switch back on , the furnace running about 4-5 hours and then ...
Furnace starts, then shuts off. - Home Improvement ' DSLReports Forums
www.dslreports.com > ... > Home Improvement
DSLReports
Dec 1, 2009 - 30 posts - ‎18 authors
[HVAC] My gas furnace cycles off every 6 minutes. ... This cycle will repeat a fewtimes, then usually after the second or third time everything ... How long is it after the big blower cuts on that the gas shuts off? ... Turn the furnace on, once the inducer blower is running you should read 0 volts (switch is closed).
Jan 03, 2016 | Heating & Cooling
When i turn the heat up sometimes it takes a long time for the gas furnace to start ..why?
Watch your furnace when you turn the thermostat up...make sure to record everything that it is doing. If you have an induced draft, forced air system, then the heat sequence of order should go like this... Initial call for heat from tstat, Inducer vent motor turns on-pulls in the pressure switch, circuit board sends power to igniter whether it is spark or hot surface, then gas valve opens. Flame sensor senses flame, burner stays on, and blower motor kicks in to heat the space. If you notice any variance from this, then something needs to be checked by an HVAC Service Tech.
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
My furnace has a new ecm motor and cycles on and off avery 20 minutes
20 minute cycles would seem to be about right...are you maintaining temperature???
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 30, 2011 | Heating & Cooling
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
585 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
