Question about Arrow T50P ARROW STAPLE GUN
Hi can't seem to reload stapler
I have an arrow staple gun and i can't figure out how to reload it can u help? it's a jt21, I have tried sliding them in but they don't go that far, I got the staples at the store i brought the gun with me, there dosen't seem to be anything jammed in it
  • 1 more comment
  • Pete B Nov 30, 2008
    Arrow T50 Stapler - Have to force the staples when loading - can only get 10mm staples to go in and then with much difficulty. 12mm, 13mm won't go in at all. The 10mm staples slide down the rails nicely once I get them in a ways past the opening. Something is jamming things up at the loading end of the rails.
    Signed
    Frustrated
  • Anonymous Mar 23, 2014
    I'm stapling cloth to plywood for a cornice board. I was not having any trouble and then after I reloaded the stapler for about the 5th time, with Arrow brand staples, I couldn't get the staples to go into the plywood anymore.
  • Anonymous Mar 28, 2014
    The gun has got jammed with the u staples and will not slide back out.
  • 32 Answers
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Posted on Nov 26, 2008
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
Won't shoot staples. Proper loading instructions please.
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
Sep 02, 2009 | Omega Easyshot Staple Gun & Desktop...
JT21 staples
no
will jam stapler
us 9.5mm
May 17, 2009 | Black & Decker 5700 Powershot Forward...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Arrow T50P ARROW STAPLE GUN Logo
1,521 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
