Question about Toshiba Satellite M35X-S161 Notebook
Toshiba Satelite M35X-S111 Beep codes on boot
Tried two different , good memory sticks. Toshiba Satelite M35X-S111: ERROR: Resource conflict-PCI serial Buss Controler on Motherboard Bus:02,Device:00,Function:00 Error: PCI NETWORK Controller on Motherboard Bus:02, Device:01,Function:00 to resume, to Setup What does this mean?
  • Kevin Kenward
    Kevin Kenward May 28, 2012
    Not exactly sure what you mean. Are you saying to short 2 points under the ram together?
  • Kevin Kenward
    WILL WINDOWS LOAD WHEN I GET THE HDD & THEN FLASH THE BIOS WORK?
  • 669 Answers
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
Posted on May 29, 2012
2 Suggested Answers
SOURCE:
MOROO007
  • 180 Answers
SOURCE: toshiba a105-s4054 won't boot
The same machine with me and the same problem I changed the BIOS of the motherboard but the problem Tlch the same message is is the last day I discovered that the problem in the chip of Intel's motherboard happens is a conflict between the PCI and Ridr and some of the various components that vary according to the case of the slide as this occurs in the organs contained in the slide as happens conflicts in the delivery at the beginning of operation of laptop and since all the inconsistencies that occur when you start up that is stored on the memory the BIOS and therefore must be emptied this memory so that the laptop from work and not doing a re- choose to run the key F-1
s this memory chip in it's protection for the BIOS that is stored by BIOS password
Points for this memory on the motherboard when you connect to these points is clear all data from storage on a slide in the Model 100 is a satellite point of discharge under the Wireless card under the keyboard and be written next to 88 **
As for in this model are under-Ram
Posted on Apr 20, 2010
M35X s111 won't boot
is the drive making any sounds, beeps, or sounds like clicking after revving up? Might need new hard drive, I had same laptop do the same thing, when it got to post, cursor of death= hard drive died. Also note that you need to replace it with a low GB drive, ATA or SATA not IDE. Try and get 80 - 120 gig if it does need replacing. For some reason I remember it wont run anything over 240G.
Good luck.
May 30, 2014 | Toshiba Satellite M35X-S111 Notebook
I have a Toshiba Satellite M35X-S109 PC Notebook that had the 1-3-3-1 beep error code on boot up for about a week. After about 10-12 restarts it would finally boot up. When I tried to boot up today the...
This still sounds like a memory issues to me. Take out one of the memory sticks, reboot, and see what happens. If this solves the problem, then remove the memory stick and out the other one in. If the problem returns, you may have bad memory. basicallym what you should be checking is each stikc in each slot - to try to determine if the memory is good - if the slot is good - and if the memory is seated properly.
Mar 28, 2010 | Toshiba Satellite M35X-S109 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Toshiba satelite m35x-s111 computer won't boot. get 1 beep followed by 3 beeps followed by 3 beeps and 1 beep. must be a coded describing boot problem
The laptop is not recognizing your extended RAM. Try removing one of your RAM sticks and restarting it. Replace and remove the other and restart it again. If it works with only one module installed, then those two cannot run together. If it will not work and you have only one in there then the RAM is bad.
Dec 06, 2008 | Computers & Internet
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Toshiba Satellite M35X-S161 Notebook Logo
340 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
