Question about IBM ThinkPad T41 Notebook
How to share internet connection using ADSL modem to two PCs/NBs
I have an internet connection using an ADSL modem (local ISP) with one PC and everything is going fine. Now, I want to share such internet connection with another one notebook or PC, what should I do then and what other peripherals should I add so that both the PC and notebook are running the internet connection using the same source.
Thank you very much! T. M. Musa Zakaria
  • T. M. Musa Zakaria
    T. M. Musa Zakaria Nov 30, 2008
    First of all thank you very much for your advice Gag!
    I finally, bought and use the ASUS Network TP-LINK 5 ports Ethernet Switch 10/100 TL-SF1005D, costs about $ 11.90. Me (using a PC, and sometimes a notebook) and my son using his PC upstairs can share internet connection absolutely well. Also a friend of mine when come to my house join the connection using his notebook. We are very happy altogether!
    Once again, thank you all, thank you fixya.com!
    Best regards,
    Musa Zakaria.
  • 34 Answers
Hello
To use same internet connection you will need wired or wireless router, I would suggest wireless router since you don't have to mess with wires, you can buy these routers anywhere best one to get is Linksys and it comes with all the instructions.
Thankyou
Posted on Nov 26, 2008
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I cant connect to two computers at the same time
How to connect....
1- Two Computers:
# We are connect two computers together to share Internet, printer, scanner, files, and even programs
We can do it through either way:
1- Use A Crossover Cable And Two Network Cards.Two network cards are installed in two computers.Then use crossover cable to connect them.
2- Use a Phone Line and Two Special Adapters Sold as "Phone line network Kit". Two adapters are installed in two computers. Then use existing Phone line to connect them.
Connecting Two Computers Wirelessly:
1- Wi-Fi
2- Bluetooth
3- Infrared
Several types of fixtures exist for home networking:
1- Hubs
2- Switches
3- Routers
2- Computer with the internet
Before you can connect to the Internet and access the World Wide Web, you need to have certain equipment. In brief, you must have:
-A computer (preferably running an up-to-date operating system); -
-A modem and access to a telephone line or a local area network (LAN) that is in turn connected to the Internet; and connection software that will allow you to establish an account with a service provider and access the Internet
You Need:
Modem: This converts your digital computer information into analogue telephone signals. Phone Line: his may be your biggest expense after the equipment.
Internet Service Provider (ISP): ISP has a permanent connection to the Internet.
ADSL: a newly standardized transmission technology facilitating simultaneous use of normal telephone services, data transmission of 6 Mbit/s in the downstream and Basic-rate Access (BRA).
ADSL facilitates the simultaneous use of normal telephone services, ISDN, and high speed data transmission.
Another advantage of having an ADSL line is not missing calls while you're online, as both voice and data can be transferred at the same time.
Jun 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
INTERNET PROPLEMS
you need
  • you need a phone line that is active for dial up,or non active for naked adsl
  • you need a dial up modem if you want dial up, adsl modem for broadband
  • sign up with an ISP (monthly cost) and obtain user name and password
  • enter user name and password (generaly via ISP cd) into (adsl)modem or setup dial up connection in windows
  • wait for ISP to notify you the line has been activated, for adsl, not dial up.
all should be good
good luck
Terry
Mar 30, 2008 | Computers & Internet
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
IBM ThinkPad T41 Notebook Logo
172 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
