Question about Sanyo DSR-3709
Disk error message
Hi, I have a security system with a Sanyo DVR 3709. A message with "Disk Error(1)" occurred on the display and  an alarm is sounding. Please help!
  • 1 more comment
  • radum Nov 26, 2008
    This is not a $10 response. You just need to give me the solution, not "IT COULD BE"
    I am waiting for a step by step solution.
    It does not let me do the format, after a minute it is initializing over and over
  • saydin003 Jan 09, 2013
    if you have a raid controller unit.check the raid system healty.after check up if everything is normal,check or replace the 68 pin scsi cable between dvr and raid unit.
  • 685 Answers
DSR-5716P/5709P
DSR-5016/5016P
DSR-5009P
DSR-3716/3716P
DSR-3709/3709P DVR Viewer2, JPEG2000 and ActiveX Plug-in Software
Version 2.1.2 DVRViewer2_2.1.2 (zip) How to install
Release note
Posted on Nov 26, 2008
  • 849 Answers
Two option
either disk is bad or drive is faulty.
check the disk on other system if it works then try to clean the lense of the drive with wet tissue paper.
good luck
  • Sanyo Master
  • 19,396 Answers
This is an 'it could be' , is an 'it it'
Disk Error(1) = Hard disk fault, either logical or physical.
If you can format the hard disk, that means that it was a logical fault, and simply formatting will solve the problem.
If it does not format, then the hard disk is physically damaged (heads , motor, control board) and then you need to replace the hard disk.
This unit support a replacement hard disk that ranges from 80 to 300 GB, get a replacement disk installed at any electronic repair shop, or call Sanyo customer service, and ask them a quote for the repair.
  • Ginko
    Ginko Nov 26, 2008
    If
    This
    unit support a replacement hard disk that ranges from 80, 160, or 300 GB.
    Get
    a good 300 GB replacement disk installed at any electronic repair shop, or call
    Contact Sanyo Security here.
    Here is the manual
    Brigadier General:
  • 3,614 Answers
This is usually a problem related to the hard disk(s) themselves; this may not mean that the hard disk is bad, but could mean incorrect cabling or another issue making it impossible to find the hard disk. The controller or interface to the hard disk could also be at fault.
There is a general failure of the hard disk. Either an error message is being displayed indicating a failed disk at boot time, or some other wholesale problem is either preventing access to the hard disk,
If your PC uses a separate hard disk controller, check all the connections to it. Try removing it from its slot and reinserting it; sometimes the card may not be seated properly and this will fix it. If possible, try switching the controller with another one and see if that fixes the problem.
    Genius:
  • 2,035 Answers
First try to reset the unit :
Press and hold "MENU RESET" button on the front panel, then press "ALL RESET" button. DVR will reboot, and release "MENU RESET button" when buzzer rings.
Note:Recorded images and MENU settings cannot be returned before the initializing.
If still the error exists then you need to replaced hard disk one in the unit ,
  • 4,234 Answers
Unfortunately, this is not a problem that is likely to be diagnosed remotely. There are a number of possible problems that can result in the symptom you describe. Something as simple as a defective power supply can cause this. The more likely cause is either a driect problem with the harddrive itself (platters or attached controller) or the driver board within the DVR. Without seeing the machine and taking measurements inside, all we can provide you are possibilities. Since this is a security system, I would strongly recommend that you see a local servicer for assistance.
I can provide a verification of the diagnosis if you wish to post the findings here that the estimate makes sense.
Keep us posted,
Dan
  • Sanyo Master
  • 13,433 Answers
Sounds like a hard drive problem, you may need to format the drive or replace it if its faulty, backup your data if possible and perform a format or similiar in the settings, it should work normally after this, if not you most likely have a hard drive failure and contact your dealer or the maker for warranty repairs if it is still covered by warranty.
  • 10,594 Answers
Download an update software of Sanyo DVR-3709 from Sanyo Support.
Please check there following latest software...
Version 2.1.2
Thank you.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, this could be indicative of a failure of the hard disk that records the video. Initially, have you tried if you could retrieve/view previous recorded sessions/dates? Additionally, if the system is relatively new, have you tried a format?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 26, 2008
    Appreciate the postback and additional information.
    On similar incidents, "failure to complete initialization", the culprit would be that the hard disk could no longer be recognized by the system and so it goes into a loop, restart look for the HD (hard disk), could not fin, restart.... To confirm, the HD must be ohysically removed from the DVR3709, attached to a SATA/IDE to USB adapter and connected to a computer. Doing this would make the DVR3709's HD as an external storage device of the PC and utilities such as scandisk, format, chdsk and others could be used.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 291 Answers
It could be the faulty disc or the lens of the player is not working and needs replacement or cleaning.
    Master:
  • 505 Answers
It may be problem with the CD\DVD or the lens may need some cleaning. First try with a different CD\DVD and check. If you still get the error try cleaning the lens using CD cleaner.
Thanks
  • 10,515 Answers
This usually (but bot always) is caused by the information in your BIOS not matching the type of Hard Drive in your system when you have an old system that doesn;t automatically detect hardware. When you press F1 it attempts to ask the HD what type it is, and since it boots OK I guess it's fairly smart.
What you need to do is enter the proper information into your BIOS for this type of Hard Drive. Depending on how "old" this PC is, you may need to specify how many cylinders and heads it has. most of the information should be on the label of the Hard Drive.
  • taran_2005
    taran_2005 Nov 26, 2008
    there can be two masters, secondary master and primary master.( Which by the way is the better way to setup your hdd configuration, 2 harddrives on seperate IDE cables) There just cant be 2 masters on one ide cable, in which case the second drive wouldnt be picked up by the bios as far as I know.
    Cant say ive seen the diskerror before so follow suggestion one and check in the bios if the drive is being picked up correctly.
Have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Mar 30, 2015 | GW Security Professional 4 Channel 1t Hdd...
Lenovo c340 6 gb How To Setup
This issue may occur if one or more of the following conditions are true:
·The basic input/output system (BIOS) does not detect the hard disk.
·The hard disk is damaged.
·Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note: Some third-party programs or disk corruption can damage an MBR.
·An incompatible partition is marked as Active.
·A partition that contains the MBR is no longer active.
Step 1: Check all hard disk and interface cables are properly connected and are in healthy state.
Follow the steps from: "Operating System Not Found" or "Missing operating system" error message when you start your Windows XP-based computer"http://support.microsoft.com/kb/321626
Or
Nov 11, 2013 | ErrorExpert
Hp labtop non system disk error
Hi, this error most often occurs when you try to boot your computer up with either a flash drive (USB drive) or a CD/DVD already in the computer. The system checks these drives first for operating systems before the hard drive, and when it doesn't find your operating system it displays that error. Remove the disk or flash drive and try to boot your computer again, and the error should go away.
Jan 21, 2011 | HP Computers & Internet
ERROR 1002
This error can occur during a system recovery, and choosing the backup option to an external hard drive. The recovery might stop responding, and an Error 1002 message displays.To resolve the error, follow these steps:
  1. After the error message displays, turn off the computer.
  2. Disconnect the external hard disk drive.The backup is still useable.
  3. To continue the system recovery, restart the computer.
  4. Press F11 repeatedly at startup.
  5. Select Advanced Options , and then select System Recovery .
  6. When given the choice, choose to continue without a backup.
  7. After system recovery is complete, restore files from the external hard disk drive.
Jul 04, 2010 | Dell Dimension 8200 PC Desktop
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Non system disk or disk error
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
Sanyo DSR-3709 Logo
549 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
