When the main burner turns on, it shuts off after a few seconds
I have a very basic Cozy W505F (2-sided) wall heater. This unit has no blowers or fans.
I can light the pilot light, but when the thermostst activates the heater and the main burner lights, it shuts down after only 2 - 5 seconds.
When this happens, the pilot light goes out too.
We recently had the roof replaced, so I checked the vent pipe in the attic.
I found a section that was cocked to one side leaving a small 1/4" gap on one side of the vent pipe, between 2 sections, which I fixed.
I want to get some ideas or suggestions before spending a lot of time tearing into the unit.
FYI, the thermal blocked flue switch does not have a reset button that is readily apparent. I believe I have an older model that has no reset switch.
I have not tried bypassing it yet.
  • 1 more comment
  • candyman1809 Nov 26, 2008
    i have the same problem, i changed out the themocouple but its still not staying on
  • contactjohnf Nov 29, 2008
    My Endless summer 200209 patio heater has not been used for a season. The pilot light lights, but goes out when I turn the control to light the main burner. I do not hear propane flowing and cannot light manulally either.
  • MikeyVice Dec 02, 2008
    I was dog tired when I posted the problem, and didn't realize that I had not even checked the heater when I got through in the attic.
    The vent repair that I mentioned in my original post did fix the problem.
    I guess it didn't have enough updraft because of the small gap.
    Sorry to waste your time, and I hope contactjohnf and candyman can get their problem solved.
    Guys, if there is a vent on the heater, try looking at that. There may be a thermal switch on the flue that can be reset, or bypassed just long enough to test. Longer than that would be dangerous.
    When I get a chance, I will try to find any actual useful information for you.
  • 1,420 Answers
You have a venting issue. Either the vent is blocked or there is combustion air entering back into the heater. Call a qualified technician right now!
Posted on Nov 28, 2008
Cleaning
clean unit when cold vacuum bottom and have an inspection done every couple years.
Feb 21, 2013 | Cozy Heating & Cooling
I have an outside vented wall mounted heater.It heats the room and before it shuts off the room gets as cold as when it started running.does that make sense?
What you might be hearing is the fan before it shuts down, the burners quit long before that. You might have a sticking fan switch thats letting the blower run to long and blowing cool air. You didnt say if your unit has a blower, I have to assume.
Feb 24, 2009 | Cozy Heating & Cooling
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Cozy hi-efficent wall furnace HEDV403
what you are doing is reseting the heater when you unplug it there should be a overheatswitch that is cutting in and shutting it down
Jan 11, 2009 | Cozy (W352E) Heater
The heater will not ignite properly
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
