Question about Microwave Ovens
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
  • Microwave Ovens Master
  • 9,098 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Microwave door spring broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 05, 2009 | Microwave Ovens
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Mar 05, 2009 | Panasonic NN-A811A Convection/Microwave...
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
The bulb is not working in my Panasonic NN-A554W inverter slimline combi oven and I do not know the size/number to obtain a replacement. I know you are supposed to get in an engineer but that is a bit...
It's a T170 type bulb (should be very common at a grocery store or hardware store) rated at 240 volt, either 20 or 25 watt is okay, and if you order it as a spare online, it may come with the 90-degree bracket.
You can see a good photo and detailed specifications here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Oven door
It's probably not the spring.
It's probably a broken spring mounting tab on either the inside panel of the oven or the "door key", which is the part that has the hook like projections that go into the chassis behind the door.
You can order Panasonic parts here: http://www.pasc.panasonic.com/epartr
(select Order Listing ByPart Number) when searching
Mar 14, 2008 | Panasonic NN-S254BF Microwave Oven
Broken Door Catch Now oven won't work
You can order parts online by entering your full model number (without dashes) here: http://www.pasc.panasonic.com/epartr Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Aug 29, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
757 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
