Question about Bosch PB10-CD Radio/CD Boombox
The power transfo is open, where i can find one
Set is dead
  • 136 Answers
I would go to their website for support on this
Posted on Apr 01, 2009
Model ogf41101 fuse blown cant read the number all works but dont heat the fuse goes to the high voltage need size of fuse
From user abu_abdillah351 has mentiond this before
the problem is the high voltage fuse, incapsulated between the transfo and the magnetron. This supports up to 5000V and usually rated something like 0.65A/0.7A/0.8A and even 1A.
When you open the capsule, you'll see it sitting there between its two connectors
Aug 29, 2014 | Microwave Ovens
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Jun 27, 2014 | VOX Amplification Vox Valvetronix VT50...
What kind of adapter do i use for my keyboard Casio ca-110
if you don't want to wait, you can go to radio shack and get a universal adapter for a bit more, but it should work no problem.
http://www.amazon.com/HQRP-Adapter-compatible-Keyboards-Replacement/dp/B004TXDL3C
May 26, 2012 | Casio Music
Sound no pictre
Check the inverter, probably one of the inverter transfo's is bad. Al must measure the same for example 800 ohms, if there is one with an higher value that is the one to be replaced. Measure at the lamp side, not the power side.
Feb 17, 2012 | Televison & Video
I connect to my HP Officejet Pro L7680 All-in-One Printer the wrong power supply and now dnt swicht on, in the back lights goes green but nothing happens. I have electronics knowledge to fix it but maybe i...
Hi live_intheda
I 'm not familiar with the device but isn't it just a question of replacing a burned fuse ?
Is the power transfo inside the unit or is it external together with the connecting power cable ?
Regards ,
fanaudi .
Mar 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
My Sony KV-36XBR800 will no longer turn on when power is pressed it clicks and sounds like it's turning on but the screen stays black and the stand by light blinks 7 times.
7 times mean no horizontal deflection. So check horizontal output an solder of it and associate parts.Often resistor and transfo driver of base of h. output.
Apr 23, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My tv smells like it's burning
Remove the back cover and look for discolored components(most likely coil or transfo),also unplug teh set after it has warmed up and touch components lightly to feel for overheating.i had burned coil in a similar set,around the pincushion circuit. good luck
Oct 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Wii console will no longer start
In the manuel, there is no mention of a cell battery in de console.
We have opened the console and changed the battery. Everything is ok now.
Apr 05, 2009 | Nintendo Wii Console
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Princeton 19" LCD flat panel monitor does not turn on. Unsure if it's the monitor of the cable/transfo..
A $10 voltmeter/amp testor from any hardware store would tell you if the power supply is passing the correct amps/volts through to the monitor. Just match the reading to the stated rating on the power supply's label. If it is giving the correct current levels, then it's your monitor. If not, you can get generic power supplies at mos hardware stores & even Radio Shack fairly cheap.
Jul 13, 2008 | Computers & Internet
Bosch PB10-CD Radio/CD Boombox Logo
148 people viewed this question
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
