When I try to download acrobat reader 9 I gbet the message: The4 older version of adobe reader 9 cannot be removed Error 1714
    President:
  • 1,073 Answers
Try to revome the old version by yourself, after that instal the new one.
If that dosent work, try to reinstal an old version first, then uninstal the same and instal the new one.
Seen this problem before, and one of the solutions obove should work for you.
Good luck
Posted on Nov 26, 2008
CANNOT INSTALL UPDATES FOR ADOBE READER 9
What error-message(s) do you get when you try?
If you're referring to the _free_ Acrobat Reader,
use Add/Remove Programs to uninstall it.
Then, download the latest version of the software from http://www.adobe.com -- most of the updates will already be integrated into the download.
If you're referring to the "full" software (that creates PDF files), find your original software, and license-key. Then, use Add/Remove Programs to uninstall it.
Restart your computer.
Reinstall from the media, using the license-key.
Then, do the "check for updates" within the software.
Apr 10, 2010 | Adobe Acrobat 9 Standard Upgrade Version...
Message: internal error occured pops up.
You will have to uninstall everything that is made by adobe. Adobe flash player, adobe active x. After unstalling that, that should let you put the adobe reader back. Then download the other program I mention earlier.
Nov 09, 2009 | Adobe Computers & Internet
I am unable to open pdf's
Go to Adobe's web site and download the latest Adobe Acrobat "Reader".
Sep 24, 2009 | Adobe Acrobat 6.0 for PC
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
Need to delete Adobe Reader 7.0.9 so I can reinstall latest Versi
I was able to remove Adobe 7.0.9 by getting feed back from "question to google crowd"!
1. I had to download a program that removed the "setup" from the Adobe 7.0.9 on my computer.
2.I then downloaded Adobe 8.1 (with the understanding that since "7.0.9" now had no setup instructions" there would be no problem with the "8.1" download) -
3.Once "8.1" was downloaded I went to "ADD/REMOVE" and removed "7.0.9" - this time it worked just fine - no message that I had to find a folder with "7.0.9" .
4.After removing "7.0.9" I removed "8.1" with the ADD/REMOVE program;
5.All Adobe was removed from the computer..I then downloaded ADOBE 9 from Adobe's website.
6.I went to my portfolio to check it out and the pages came up without a hitch.
Goodluck to those who have had a similar problem.
peh51
Jan 15, 2009 | Tiny Computers B1996 19" CRT Monitor
Cannot use reader 8.0,cannot remove it or install 9.0
oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
Dec 24, 2008 | Dell Dimension 8400 PC Desktop
I am having a problem with Adobe Reader 8.1.1. I am using Windows XP. Originally the program ran fine, but lately when I click on a link on a website that uses Adobe Reader I get a message that says...
do you the original installer of your adobe reader?
if you..when uninstalling adobe and the error occurs just browse for the .msi in your adobe installer and hit ok...
after it uninstall...download foxit reader and install it instead of the adobe reader....
hope this helps
^_^
Mar 16, 2008 | Computers & Internet
Problems with Reader
Look under the Run the Microsoft Clean Up utility before you install Acrobat or Adobe Reader header at http://kb.adobe.com/selfservice/viewContent.do?externalId=320310:
DK50, your problems seem to stem from corrupted registry key(s).  While this should fix your issue in the short-term, bad registry values are never a good sign.  I would suggest you visit microsoft's site and search for a registry repair utilities for your operation system version such as http://www.microsoft.com/downloads/details.aspx?familyid=56d3c201-2c68-4de8-9229-ca494362419c&displaylang=en (windows 2000).  As a rule of thumb I always recommend a complete fresh install every 2 - 3 years (at least) and of course only after backing everything up.  Hope this helps.  =)
Oct 22, 2007 | IBM ThinkPad T41 Notebook
Adobe installation
Hooray! Found the solution. Seems the problem is you must have the Adobe Reader 7.0.9 installer on your system to be able to install 8.1.1. You can d/l version 7.0.9 (which includes the installer) here:
http://www.adobe.com/products/acrobat/read...llversions.html
Install the whole thing, then you should be able to install your 8.1.1, which will remove the 7.0.9 version in the process, but will use its installer.
Oct 20, 2007 | Tiny Computers B1996 19" CRT Monitor
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
