Question about Necchi 3537 Mechanical Sewing Machine
Making a buttonhole on a Necchi 3204 sewing machine
I have a new Necchi 3204 sewing machine...I want to learn how to make buttonholes and have a template attachment. My manual doesn't have any instructions how to use this thing. Can anyone please help me????
Many thanks!
  • ladylan Dec 02, 2008
    thanks for the help!!! I'll try that tonight...
    take care...
    ladylan
  • Anonymous Mar 22, 2014
    manual
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Posted on Mar 04, 2009
  • Leslie Hodge
    Leslie Hodge Nov 09, 2014
    hello I need help threading necchi 3204fb model
You will notice that there is a dial to make button holes. Yes, use the template and turn the nob to form the four sides of the button hole. Try it on a scrape of fabric until you figure it out. That is what I do. Good luck!
Trudy
Posted on Dec 02, 2008
Hi can’t make the button hole big enough using the special one step Pfaff foot . Won’t go bigger than 8mm
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
How to Make Buttonhole on Your Sewing Machine Sew4Home (several methods)
Creating Buttonhole Using Sewing Machine
how to sew buttonhole without buttonhole foot Google Search
Jan 26, 2018 | Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
How do make buttonholes with the Necchi 3102? I followed the instructions from the manual but cannot get the machine to properly make the buttonhole. Any suggestions? Persimmon
Expand exactly the symptoms of what is not working with your buttonhole function. There are generally 5 or 6 steps to a built-in buttonhole, so we need to know which function(s) is/are not working.
http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/3101FA_3102FB_Instruction_Manual.htm
BTW, any zig-zag sewing machine can be used to make buttonholes without the built-in buttonholer or a buttonhole foot. The built-in buttonholer just took the manual method and made a dial to switch to the next step. You can do that manually on your machine. You just need to perform each step manually: knot-on, stitch the bartack, zig-zag forward, bartack, zig-zag backward, and tie-off. I've made many buttonholes manually on sewing machines before having a machine with built-in buttonhole or a buttonhole foot. Just be sure to practice on some scrap fabric first before trying it on your garment.
Until Wednesday Calls How To Manual Machine Buttonholes
Nov 07, 2016 | Necchi Sewing Machines
Is it possible to override the automatic buttonhole setting on a Necchi ex30?
Are you asking if you can do a buttonhole without the special buttonhole feature? If so--of course you can. Sewists do it all the time on machines without the buttonhole feature or special feet. Be sure to practice on some scrap fabric first.
Feb 25, 2016 | Necchi Sewing Machines
1995 400 series need to make a button hole
Consult your owner's manual. If the machine has a buttonhole function, you will find the instructions in the manual. If not, never fear as you can make buttonholes with any machine that has zig-zag capability. You can find a multitude of web sites and YouTube videos to learn how to make buttonholes on a machine without the buttonhole function. Just be sure to practice on scrap fabric and get the process working well before trying it on your garment.
Dec 21, 2015 | Husqvarna Sewing Machines
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
What feet do i buy for necci 6015c
I have 2 necchi sewing machines & have the following feet
1.all purpose foot
2.zipper foot
3.buttonhole foot
sewingpartsonline.com has necchi parts
Dec 02, 2010 | Necchi 6015 Mechanical Sewing Machine
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
Oct 14, 2009 | Husqvarna Viking 1
Buttonhole
Dud you pull the button hole lever down so that it engages the foot?
sewman7
Jul 17, 2008 | Necchi 3102 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
652 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
