Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
I just need to change the date on the machine (PanasonicUF-490) I started this job and there is no one to train me, no manual that I can find, etc. The fax machine works well, the energy saver mode is usually on, we don't use it that often, but I noticed that the date is a day behind so that our faxes say the day before. Can you give me a simple solution to change the date? I don't want to mess anything else up.
  • 488 Answers
Please see this
the manual is located inside FixYa here
hope it helps!
Posted on Nov 26, 2008
How to change date
hit function button number 7,1 set date time hit start to save.
Dec 17, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Setting the Date
function-7-1-start-enter time and date-start-stop your done
Jan 30, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Un-do fax forwarding on panafax uf-490
if you cant find solutions for it
try the all job clear
PRESS FUNCTION 7 MONITOR(4x)
using arrow down or up
locate for RAM INITIALIZE then press start
arrow up or down again
locate for ALL JOB CLEAR then START
HOPE it helps.
GOD BLESS
John 3:16
Aug 08, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Reset fuser but the display keeps blinking
if its blinking it might need the time and date adjusted . Function-7-1-start-start-
Jul 14, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Panafax uf-490
turn off memory and send direct, it will dial, connect then send you will need to make sure that your sending settings havnt been alteredand that you can get an outside line.if that dont work it may be a little more involved, but thats the start
Jun 12, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Comm 503
That is "CS of modem is not able to turn ON during training." It could be a bad SC circuit board, but usually that's a bad line or connection. Get your phone lines checked out by your phone company.
If that doesn't do it, then you'll have to replace the board in the fax machine.
Nov 19, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Printer Code and Power Failure Error
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
Oct 29, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
46 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
