Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
How do you clean an oven with the clean control knob. We have a modern maid
  • Ilk2sing Jan 28, 2009
    I have a Modern Maid oven but cannot find the instruction booklet. I have a knob I turn to "clean", and a latch to close the oven door. The step I am forgetting is how to set the timer controls.
  • 833 Answers
Generally, there is a latch which closes the door on some units...on others it is electrically actuated.  Turn the controls to clean.  Generally, there is a function control and a temperature control which must be activated.  This will latch the door electrically.  A two hour cycle is about right for most soil, if you're given a choice.  Ventilate the area...it smells!  The door will unlatch about half an hour or more after the cleaning stops.
Posted on Nov 26, 2008
My maid left a tupperware container in the oven and I baked a casserole in the self cleaning oven. How do I clean it?
You will need to physically remove as much as possible. A plastic putty knife or similar will work best. Use a hair dryer to gently heat the plastic to make it pliable and easier to remove. The oven will need a thorough cleaning once you have removed as much plastic as you can.
Oct 25, 2016 | Ovens
I have an old Modern Maid double oven. DK 0757. Broiler comes on everytime I try to heat for baking. Any suggestions
It was common for the broil element to come on during the preheat time on older oven controls. When the oven reaches temperature the broil should shut off. If this just started then the points in the broil switch section are welded together and the oven thermostat will need replacing
Mar 20, 2015 | Ovens
HOW DO I KNOW IF MATSUI OVEN IS SELF CLEANING?
If it doesn't come with a little maid type female with a scrubbing brush and rubber gloves, you have to clean it....
Jan 11, 2015 | Ovens
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Modern maid toaster kbt 100
thay 2 soi day moi vao
Feb 17, 2014 | Ovens
I have a Fridgidaire Galaxy Oven,can you tell me how do I set the self cleaning oven?
Greetings,
I can't locate your model number, but, if you have the one with an electronic control..just put it to clean and maybe set the clean time and it should start the cycle and lock the door by itself and start cleaning.
if it has knobs for selector, and a knob for oven thremostat and a clock with two or three knobs.
put the selector on clean, put the thermostat on clean and then go to clock and set the stop time three hours past the time thats showing on your clock(providing its keeping time) and lock your oven door and it should start.....Bruce Denton
Dec 13, 2010 | Frigidaire FFEW2725LB Oven
How do I clean my oven? Model #RF354BXWD?
At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
Remove the racks and pans from the oven.
1. Move the Lock Lever to the right-the Clean position.
When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
2. Set the Oven Selector and Oven Temperature Control Knob to
CLEAN.
3. Make sure the clock and Start and Stop Times all have the correct time of day.
4. Push in and turn the Stop Time Knob clockwise two or three
hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
NOTE: Make sure the Start Time Knob is not pushed in.
5. After the Self-Cleaning cycle is completed and the oven has
cooled enough, the Lock Lever can be moved back to the left.
DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
6. After the oven is cool, wipe off any residue or ash with a damp cloth.
If needed, touch up spots with a soapy steel-wool pad.
Manual
Jul 30, 2010 | Whirlpool Ovens
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
311 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
