Question about Casio KL-100 Label Printer
Set key not working
It appears that the set key is not working. No matter what function I use and press Set to confirm - my selection stays on the screen.
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
Mar 06, 2015 | UPM Hardware & Accessories
Coil not reset odo after oil change please let me know how I can reset
1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3
i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1)
i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and
-, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3)
i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3)
i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and
-buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and
-, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i
If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3)
i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
Copyright
Jun 22, 2012 | 2006 Mercedes-Benz R-Class
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Fax confirmation
1. Press Function key
2. Press Data Registration key
3. Press Set key
4. Use (up or down) arrows to select REPORT SETTINGS
5. Press Set key
6. Use arrows to select TX REPORT
7. Press Set key
8. Use arrows to select OUTPUT YES
9. Press Set key
10. At PRINT WITH IMAGE, use arrows to select YES or NO (YES will print the first page of the fax with the report)
11. Press Set key
12. Press Stop/Reset key to exit menu
May 23, 2008 | Canon FAXPHONE L80 Laser
Changing settings on innovage telephone
hi big al,
on my phone you hit SET/SAVE, press UP/DOWN to find the function you want, press SET/SAVE again to select, press UP/DOWN key to program. press SET/SAVE to confirm. i can email you a copy of my manual if you'd like. my email is all8upinwv@yahoo.com hope this helps.
tammy
Apr 19, 2008 | Innovage Speaker/Caller ID* LCD Touch...
Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Feb 20, 2008 | Canon FAXPHONE L80 Laser
Setting clock
First select calender press enter. to set date press stop then use < arrows > to set year, up and down to set month, press stop to comfirm. Then use navigation buttons to select cuarrent date and press enter to confirm. To exit press menu button.
Use nav buttons to select clock, press enter to confirm the clock display will appear.
To set clock press menu for custom set up. Use down arrow key to find "set time" right arrow to kighlight set time press enter, then arrow keys to set time then enter then left arrow all the way to the left then down to exit, athen enter.
Hope this helps.
chuck32
First hit setup then find settings, then enter. Use arrow keys to change time, then enter
Feb 03, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Casio KL-100 Label Printer Logo
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
