How do I set up remote access on IP Office? - Computers & Internet
  • 367 Answers
Please provide more information, What os your running etc. Also there are tons of programs out there for accessing your pc remotely. IE Radmin
Posted on Nov 26, 2008
Cisco 7942G IP phone works in home office but it does not work in remote location
Hi J,
Typically corporate use VPN for these kind of critical service access. Check with your IP Tele/Network admin and get VPN access or may be OfficeExtend or any other solution employed. Corporate don't expose their UC servers on internet w/o security.
Oct 14, 2012 | Cisco 7942G IP Phone
Which system is this phone on? IP Office Communication Manager?
There is a button that looks like an envelope, pressing that should get you there. But if it doesnt, voicemail could be down.
Dec 19, 2011 | Avaya 1416
Nokia IP 260, allowing a remote office having a direct connection
You should disable NAT between your local networks in the Checkpoint NAT policy (Create a NAT rule above all and put all your networks in the source and destination - as a group)the leave Original in the translation column.
Jan 12, 2009 | Nokia IP 260 (2 Pack) (NBC0260000)...
D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp:// to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the is the IP address of your office, this should work. Be sure you apply a password or anyone going to will have access to you router, I also recommend changing the port from 80 to 8080 so that has to be typed to access the remote management interface.
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is then you will issue : ping PC-100 or ping If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
Nov 02, 2008 | Computers & Internet
IP Phone available for IP office?
Hi TexasTom,
I'm not quite clear on your problem. But I think what your describing would be difficult to archive. That's if I understand you correctly!
Perhaps what you might want to consider is this sort of device. It allows to normal (PSTN) telephones to be used as either SIP (VoIP) or as normal PSTN telephones. It does not require a PC once it's been set-up.
Hope this helps.
Kind regards,
Spare head 2.
Jan 04, 2008 | Avaya 5610 IP Phone
Cant access the Zyxel IES-1000
Just a suggestion...try to loop-back ping to make sure YOUR still on the network. If you are have you tried tracert? The IES-1000 is an IP-based DSLAM, so you should get something back. Here is a link that may help you a bit more
Sep 20, 2007 | Zyxel IP Express IES-1000 (91004098002)
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: Remote IP Netmask: Remote Gateway IP: Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: Remote IP Netmask: Remote Gateway IP: Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Computers & Internet Logo
David Payne
David Payne
