Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
Posted on Nov 26, 2008
Run few seconds then quits flashing 3 green lights
Frigidaire precision wash
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1428
Points
7
If all 3 are flashing it means there was a power failure. Check your power connection to make sure when the washer is coming on it is not knocking them loose.
1helpful
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
2helpful
2answers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
2helpful
4answers
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
28helpful
3answers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
3helpful
2answers
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
