Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door motor does not operate
I have a sears 1/2 horse model 139.53975srt1. The motor does not seem to come on. when I push the wall switch,keypad switches etc all I hear is a click coming from the unit. everthing else seams to work properly(lights, photo-electric door sensor) the unit is not very old(7 yres)
note: i dont know if this matter but the keypad back lighting also blinks a few times after I punch in the code(i dont recall if this is normal)
I unplugged the main powerfrom the outlet to "reset" it but no luck.
any help would be appreciated
  • 504 Answers
YOU MAY HAVE A BAD MOTOR STARTING CAPACITOR OR CIRCUIT BOARD GOTO LIFTMASTER.COM AND DOWNLOAD THE FREE PDF FILE FOR A MODEL 3280 THE TROUBLESHOOTING GUIDE IN THIS MANUAL SHOULD HELP.
Posted on May 28, 2010
Why doesn't the door move when i press the wall button it just hums?
Anthony, Since It's humming you know it's getting juice. It could be the the same exact problem I had on our Sears Liftmaster. First remove the cover and check the set of nylon gears to see if they try to move when you push the button. If so, the motor is probably ok.
The gears operate off a worm drive and come as a set, and sometimes they jam or are worn out. If the motor runs after pulling the gearset it's good. Go to Chamberlain for the parts. They're cheaper and faster than Sears. If want a diagram, for that model google one form their website and you can see how to take it apart. Ken
Feb 04, 2015 | Sears Craftsman LiftMaster Chamberlain...
The motor in the openner is not running at all, 1/2 horse power crafman. 315mhz garage door openner,model 139.53914D
Have you checked the house circuit breaker? Do the lights come on? Is the door stuck in the open position?
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage opener went up and the stopped mid way.. motor is humming but nothing moving.. sears 1/2 horse model 2000. Thanks John
Tries unplug,replug it back like about an hour latter.The unit now should be resetting itself,should work again.Still have same problems later,the motor should be check out and fix.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Craftsman 1/2 horse garage door opener. When I push the button, I can hear it hum, but the chain won't move and it seems the sprocket is frozen?
If your door is stuck in the open position you will find the trolley is jammed against a bolt just in front of the motor unit. Remove that bolt and run the opener until the door closes. Now locate the 'up limit' control on the side of the motor unit and turn it 2 times in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor works but does not move chain on half horse sears
Clutch? need more info.. wall mount or overhead? If it's wall mounted it could be the clutch, I don't think overheads have a clutch though. The first thing I'd do is get on a ladder and see if the chain is still attached to the sprocket... good luck
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
My door comes down part way and the motor keeps running.
Sounds like the gears might be out of the operator. If you can remove the cover see if there are white shavings in the cover. A Craftsman operator will take gear kit # 41C4220A
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
I have a Sear 1/2 horse power Garage door opener problem 41A4315-6c
YOU CAN BUY A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN UNIVERSAL RECIEVER THAT PLUGS IN THE WALL.AND WIRES TO YOUR PUSH BUTTON.
Sep 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
480 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
