Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printing Cartridge error
I keep having a problem with my MP830 stating that the following tank cannot be recognized, when I reset the cartridge in the printer, then I get an error of U071, more than one ink tank of the following color is installed.
There is only one cartridge of the yellow in the machine and it is the correct cartridge. Please help
  • 3 Answers
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Posted on Nov 26, 2008
My printers window states ink tank cannot be recognized....they are all new ink tanks.......mp830 printer
Open the main cover and the carriage will move to allow you to remove the cartridges. Look to see if the red light is flashing. This will indicate which ink tank is causing the problem. Change it for another new one. if it now works then return the faulty cartridge to your supplier.
May 10, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
Error code U150 on Pixma MP830
U150 error is ink tank not recognized, it happens alot on the y cartridge. i would advise you to get a version 3 cartridge. on the back of the cartridge if you hold it in the right light you will see a code like 2AHU 3FGH, this tells us its a version 2, i would maybe buy a version 3 or 5 with a updated chip, this will work fr you, if the fault is still there then the 4 contacts in the carriage unit that reads the cartridges is prob bent or broken!
hope this helps
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
U150 canon pixma MP830 "the following inktank can not be recognized" magenta. Please help, Thanks, Ted
I have had this problem repeatedly lately. To try the Stop/Reset solution already mentioned, I turned on my infrequently used Canon Pixma MP830. Most of the time at a fresh startup it gives an alarm message "the following ink tank cannot be recognized" OR "there are two of the following ink tanks installed" ??! for the single black 8 cartridge !, a Canon original. Of course, tonight it started just fine, but the methods I have used when it does not work because of these alarms are the following:
I open the top, wait for the cartridge carrier to center, unsnap the black 8 cartridge, then snap it back in and close the top. This sometimes works if repeated until the machine recognizes it. Sometimes I unsnap all the cartridges and resnap them. If this doesn't work, I remove the black 8 entirely and use a clean cloth to wipe the electrical contacts of the cartridge in the direction of their length and reinstall. It sometimes takes a repeated combination of these steps and sometimes the two different alarm messages will appear alternately. There does not appear to be any logic to it. Once the machine does recognize it, it works just fine.
However, if the machine is turned off, many times when it is turned back on later I have to go through all this frustrating rigamarole again. I hope it is a glitch with this particular cartridge (fairly new) and not the machine. Next time I get the alarm messages I will definitely first try the Stop/Reset button solution suggestion, but I thought I'd add my two cents solution, which so far has eventually caused the machine to recognize the cartridge.
May 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge
clean the contacts of the inkcartridge chip e.g. with spirit
or
Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shown correctly
May 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Defective Ink Cartridges for Canon PIXMA MP830
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
Jan 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
242 people viewed this question
old marine
old marine
